charge or pi?
If you just do the PI swap you will end up wanting more power. If you just get a blower you will end up wanting more power. Why not build up your bottom end right now and throw in some low compression pistons and do the PI swap and get a supercharger. It will save you money in the long run on install unless you are doing it yourself. This modding game never ends so do it right the first time or you will spend a hell of alot of money on it in the long run.
stangGT97 said:
install PI cams/intake and run a centri setup of your choice, or just PI cams and the FRPP roots blower
I like the sound of that setup PI cams and the FRPP supercharger.
Only running 6 psi. your engine will last a long time probably.
Also the tune that comes with it is kind of rich from what I hear.:D
Just don't expect alot of power only running 6 psi though.
