Charging Issues with Underdrive pullies
OrangeMustangGt
1,976
Cape Cod, MA
I know i've read this before, but i wanted to confirm what i found. Ever since my underdrive pully install, my car's voltmeter would hunt down low at idle.
I just replaced just the alt pully with the smaller stock one, and wanted to say that it helped the charging 100%.......i dont know but i could swear that it idles better now also.
Hey Kyle
I see my lights dim a bit during idle with mine. I have never paid much attention to the meter however. I idle at around 850. I did once set the idle at 900 and ran it for a while and I noticed the dimming was gone while using the higher setting.
What you think you have noticed could very well be a reality. You got some parameters in the pcm that + or - injector pulse width based upon battery voltage. Since you moved to a different sized alt pulley, the pcm most likely changed your af ratio to a value you Stang responded better to.
Grady
