charging problem
rowdie- stang
172
augusta ga
I need some help, I have a optima red top battery that test good, I also replaced the alternator. According to my gauge my alt is not charging the battery. I have checked grounds and wires. Where does the volt meter get the reading from. Could it be the gauge (it is stock) Also my car has a dead battery after a few days of driving.
Charge the battery and note battery voltage (should be around 12.6 volts).
Start the car and note voltage at the battery. It should be around 14+ volts.
If it isnt, check the 14 gauge fusible link that was mentioned before (it's off the starter solenoid). Then run down the regulator wiring.
I'd note that I have received new alternators that didnt work right - it's possible.
Good luck.
Or since you can drive for a couple days, you can take the car to the parts store for a dynamic test - no muss or fuss.
Good luck.
