  • SN95 4.6L Mustang Tech
Cheap PLenum
  • Thread starter Thread starter Hunter-White
  • Start date Start date Nov 18, 2005
Hunter-White
162
Jonesboro Arkansas
Nov 18, 2005
  • Nov 18, 2005
Found this here in partshopper and it seems to be pretty cheap but then again I dont have much experience at all with plenums. What do you guys think?
C&L-711(A) 4.6 2V Plenum $154.95
Nater
239
Maplewood, MN
Nov 18, 2005
  • Nov 18, 2005
C&L are pretty good. There is an article or two on www.modulardepot.com comparing a few plenums. Accufab performed the best but not by much.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Nov 18, 2005
  • Nov 18, 2005
C&L are good plenums.. but ya can't go wrong with accufab
F
flipnsac
159
Northern CA
Nov 18, 2005
  • Nov 18, 2005
If you're on a tight budget (like most of us) you might be better off just getting an intake spacer for $40. Same HP claim for much less money:
http://www.mustangtuning.com/mu4gtinsp1.html
Hunter-White
162
Jonesboro Arkansas
Nov 18, 2005
  • Nov 18, 2005
Thanks alot man that would prolly do the trick. Would it be very wise to get TB to go along with the spacer?
stangman
2,690
10
69
in a 3 bed, 2 bath
Nov 18, 2005
  • Nov 18, 2005
ummm......NO. there's a BIG difference in a claim & being able to back it up. no spacer is gunna put down 8+rwhp
BennyBlown2v
1,233
Carmel, INdiana
Nov 18, 2005
  • Nov 18, 2005
This is the same peice as the C&L under a different brand name... $50 cheaper...
F
flipnsac
159
Northern CA
Nov 18, 2005
  • Nov 18, 2005
I didn't say it was guaranteed to put down 8rwhp, just said it claimed to, just like the plenum ads do and the spacer ad does:
http://www.mustangtuning.com/mu4gtinsp1.html .
Only way to know for sure is a before & after dyno run. But if this guy was trying to save money on a cheap plenum, I was trying to give him a less expensive alternative. I've seen guys on this and other forums say they've dyno'd after installing after-market plenums and gottten only 1-2 rwhp, if that. Caveat Emptor.
Skeptics should address the advertisers not the messenger.
stangman
2,690
10
69
in a 3 bed, 2 bath
Nov 18, 2005
  • Nov 18, 2005
the messenger apparently knows better, & shouldn't spread something he knows full well isn't true. & if ya want to get all technical like, very few dyno runs couldn't be argued after being done
F
flipnsac
159
Northern CA
Nov 18, 2005
#10
  • Nov 18, 2005
  • #10
Man, have someone remove that hair up your a$$.
The truth is, I don't know for a fact whether or not the spacer helps to get 7-8rwhp. Stop putting words in other people's mouths. Like I said only dyno runs can prove it. This info is already on the internet on Mustang Tuning and Steeda's websites. Take your BS to them.
stangman
2,690
10
69
in a 3 bed, 2 bath
Nov 18, 2005
#11
  • Nov 18, 2005
  • #11
no said hair to be removed. i'm just stating it the way it is. if you don't like it, learn what your trying to talk about, come back, & try again skippy. & here is the problem with what you said...........
you said go get this product it has the same claims. the guy goes & gets it (hoping to save some money), realizes it didn't do anything, & then has to turn around & buy the right part. that's money spent twice. most people don't have the money to be spending twice. so ya see....i'm just looking out for him. & ya know what, i'd do the same for you if you posted a thread & someone else was spewing out misinformation
Red35th
609
Houston, TX
Nov 18, 2005
#12
  • Nov 18, 2005
  • #12
For the few that care the C&L is designed and made in America. The GMS crap is a direct ripoff and their stuff almost always comes from China.
Not a big issue, just tossing it out there...
stangman
2,690
10
69
in a 3 bed, 2 bath
Nov 18, 2005
#13
  • Nov 18, 2005
  • #13
very good point, i like it
BooWFO
991
Louisville, KY
Nov 18, 2005
#14
  • Nov 18, 2005
  • #14
Stangman- one not arguing with you. But how many people can feel a 5-8 hp increase? I know you can see it on the dyno or in track times but FEEL it?
Ok on the spacer deal here is a theroy I read most of the better aftermarket ones are taller the same as a stock plenum with a spacer. IF you were to port the peices to match would you get an increase in power? Just wondering since the spacer was already brought up.
F
flipnsac
159
Northern CA
Nov 18, 2005
#15
  • Nov 18, 2005
  • #15
Please stop putting your words in other peoples' mouths. Your take is not what I said. Everyone has to make up their own mind in the end. (CAVEAT EMPTOR- MF) Now go away............. but before you do, prove to everyone that a spacer doesn't do what it's advertised to do. Otherwise, you are just spreading your assumptions.........and if your proof is backed up by facts, I will go along with it.
stangman
2,690
10
69
in a 3 bed, 2 bath
Nov 18, 2005
#16
  • Nov 18, 2005
  • #16
i'm not putting words in anyones mouth. you said it, didn't know what you were talking about, deal with it. i ain't mad & just cause you were wrong don't try & point the other way & take the attention away from the point. it's been done, if you want proof, go do some research
BooWFo - it's never really a 'feel' factor. heck the biggest mods i've done to my car, i've actually 'felt' the least gain, but yet picked up 20+ rwhp.
& yeah if you were to go about it like that (with the plenum spacer & ported plenum), i'm sure it'd work out well. how well not a clue, butyou'd definately pick up some. a engine is basically a big air compressor, the faster you can get air in & out, the more efficiently it works
Hunter-white - i apologize for the hijack. i won't contribute to it from here on out
F
flipnsac
159
Northern CA
Nov 18, 2005
#17
  • Nov 18, 2005
  • #17
Nice cop-out....
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 18, 2005
#18
  • Nov 18, 2005
  • #18
People make up their mind on proven facts IE: Dyno results and actually hold and using the product.
Do you actually believe in 'advertized' hp??
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Nov 18, 2005
#19
  • Nov 18, 2005
  • #19
Its like a cat-fight in here. Being a newbie to Stang's....although a quick learner.....I do look to this place for advice. If someone has direct knowledge or research proven facts...then I like to hear the claims. If its just a thought or suggestion, label it as such. When I respond to a thread, I preface it with "I don't know shi!@#"...but here's my opinion!
But again...as I've read a million times on here....YOU GET WHAT YOU PAY FOR! If its cheap, then you're getting cheap *****
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
