  • SN95 4.6L Mustang Tech
Check Engine back on!!
  • Thread starter Thread starter Blue Mach
  • Start date Start date May 7, 2004
Blue Mach
141
Celina Texas
May 7, 2004
  • May 7, 2004
Ok once again that damn check engine light is back on. Autozone pulled the code and its the same one p1443. I have checked eveything that people have told me to look at and nothing looks wrong. Anyone have anymore help on this one? It looks like I am going to take the stang to the shop on Monday if I cant find the problem this weekend.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 7, 2004
  • May 7, 2004
is that the code for a EVAP system control valve? if it is one if the easy fixes is to change the valve
Blue Mach
141
Celina Texas
May 7, 2004
  • May 7, 2004
change the system control valve?
I dont see one on autozone's webpage?
Blue Mach
141
Celina Texas
May 7, 2004
  • May 7, 2004
I just called autozone and they called it the purge valve and thats a ford only part.... They also told me to check the hose connecting to the purge valve. I have looked though the book and I dont see a picture with the location of the purge valve, does anyone know where it is? and what the H*ll it looks like?
R
Roger_4.6_96
1,209
Reno,NV
May 7, 2004
  • May 7, 2004
Its no big deal ive had that code come up last 2 years i noticed it only comes on when i drive on the highway for 15 minutes or longer but then it gos off
pony_vert02
285
AUSTIN,TX
May 7, 2004
  • May 7, 2004
check out here:
http://web.ask.com/redir?bpg=http:/.../spider/2/forumdisplay/f-5-p-3.html&qte=0&o=0
hotmustang331
2,967
Bastrop,TX
May 7, 2004
  • May 7, 2004
Not sure about the pre 98s,but the 99+'s will fry the CPU if you let a check engine light stay on for more than 8hours.A local mecanic told us that,so not sure if its true but just thought I would warn ya.BTW he told us about it so we wouldnt fry it on a 00 V6 that my dad has.
slvrbullIT
635
Dallas, TX
May 7, 2004
  • May 7, 2004
hes yankin your chain, he just wanted to fix it and make some money. theres no way it will fry the computer.
Blev
1,295
So. Cal. V-Town
May 7, 2004
  • May 7, 2004
If that's the case my car would be dead. I have had a MIL since last weekend. Aside from it being annoying, it doesn't hurt anything. Unless you have a major problem you don't fix.
slvrbullIT
635
Dallas, TX
May 7, 2004
#10
  • May 7, 2004
  • #10
tru dat
M
mijo_latino
179
Canton, Michigan
May 7, 2004
#11
  • May 7, 2004
  • #11
problem soved
I had that same code come up over a month ago. Fixed it in 30 min and 70 bucks. There is a purge valve(~$40), and selenoid(~$30) that goes after it. My cousin, who works as a mech. at the dealership told me to replace both. Whats $70 i say when you have that ugly yellow light in your face all the time. The service shop at the dealership had the parts, bought them, changed them out. No more light.
They are located by the firewall on the back passenger side. They are on a long small tube running from your TB somewhere around there. One of them has some wiring hooked up, the other doesn't. I suggest maybe switching out the tube pieces too( both about 12" long), as mine were kind of grody. I would take a pic, but camera is broke. I could draw one for ya, heh. Hope that helps.
yay, i finally helped someone on here.
boris
35
Seattle
May 8, 2004
#12
  • May 8, 2004
  • #12
P1443 is one of many evaporative emissions fault codes. EEC V has to keep track of the fuel vapors in the system and how much of it is let back in the engine. It does so a number of ways but to cut to the chase, your code is usually caused by either the Purge Flow Solinoid (valve) or the Purge Flow Sensor. Replace them both and get them from Ford. Sometimes the carbon canister will deposit little bits of carbon dust in the sensor. Remove the sensor and tap it lightly over a piece of paper, if little black specs fall out, your cansiter should be replaced also.
Blue Mach
141
Celina Texas
May 8, 2004
#13
  • May 8, 2004
  • #13
Thanks to all for the information. I will stop by Ford on Monday and buy the purge valve and selenoid. I will also check the canister.
GoBabyVroommm
1,156
Chicago, For Realss???!!!
May 8, 2004
#14
  • May 8, 2004
  • #14
Honestly i think mustangs should just come new with the check engine light on. I really dont' remember a time that mine didn't come on.
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
