check engine light trouble
  • Thread starter Thread starter white_97_GT
  • Start date Start date Aug 1, 2006
white_97_GT
76
Ontario, Canada
Aug 1, 2006
  • Aug 1, 2006
my engine light comes on once the car is warmed up, like say after i get off the highway and im goin down a normal road, it comes on, any ideas??
o2 sensor?
bill302
2,131
alabama,gadsden
Aug 1, 2006
  • Aug 1, 2006
pull the codes and post results autozone will pull the codes free.
white_97_GT
76
Ontario, Canada
Aug 1, 2006
  • Aug 1, 2006
problem is, the light turns off when the car is shut off and doesnt turn back on untill it gets warm, can they check an old code?
bill302
2,131
alabama,gadsden
Aug 1, 2006
  • Aug 1, 2006
it should hold it in memory..
white_97_GT
76
Ontario, Canada
Aug 1, 2006
  • Aug 1, 2006
any idea for how long?
i have a 90 lx if that makes a difference
bill302
2,131
alabama,gadsden
Aug 1, 2006
  • Aug 1, 2006
until you clear the computer at the harness or by disconnecting the battery for a period of time..
white_97_GT
76
Ontario, Canada
Aug 1, 2006
  • Aug 1, 2006
ok, thanks, ill have to see if i can find somewhere here in ontario that does that like autozone
bill302
2,131
alabama,gadsden
Aug 1, 2006
  • Aug 1, 2006
heres a link (below) if you can't find anyone to pull codes you can pull them yourself with a test light or an analog voltmeter
http://www.muscularmustangs.com/test1.php
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 2, 2006
  • Aug 2, 2006
Stored codes reamain resident for 87 startup cycles.
Dump the codes and see what the computer says is wrong… Codes can be present without setting the Check Engine Light.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
