Check Engine Light
  • Thread starter Thread starter TrophyHead
  • Start date Start date Apr 16, 2004
TrophyHead
1,195
11
49
PA
Apr 16, 2004
  • Apr 16, 2004
Did 88's have a check engine light?
Is there a way I can disconnect something to have the light automatically come on?
I've seen all the other lights on.... like low coolant, battery, brake. But never the check engine light. I know this is a good thing but I had the car for 2 years and not once did it light up.
Who has a high mileage 5.0 and never seen their check engine light come on? I just want to see if this is common or if I should check the bulb.
Thanks
HISSIN50
34
129
Apr 16, 2004
  • Apr 16, 2004
i have an 88 GT vert (AZ car) and wondered the same thing. from what i gather, SD cars dont have a functioning CEL. there is no bulb, and even if you put one in, it does not work. they get functional on MAF cars.
NeQX
904
Infront Of You, NY
Apr 16, 2004
  • Apr 16, 2004
I didn't notice a low coolant light cranking on mine, odd... another thing I found kind of useless is that other panel I think its on the lower right, never seen anything on there light up , what about you guys?
HISSIN50
34
129
Apr 16, 2004
  • Apr 16, 2004
the "GT" pod (4 lights) on the lower pod (right of the ignition switch) works on mine. it has low fuel, low oil, and two others (low coolant?). they all should work. not too tough to pop the little cluster out and replace bulbs. it should work, though.
LX302
Stanger
728
Bethlehem PA
Apr 16, 2004
  • Apr 16, 2004
Right, info is right that's posted, but here is a summary.
'87 & '88 SD car didn't have a bulb in the instrument panel for the CEL, even though you can find it on the tach.
'89 and up do and it is wired into the EEC. Putting a bulb in the SD cars will only get the bulb to light when you turn on the ignition.
So to check codes, you need to use the plugs in the engine bay in the back left corner of the engine bay, next to the wiper motor. You should do this periodically or when the car is not running right.
The low fluid indicators, like "HISSIN50" said only work on the GT's and it is in the lower right of the dash, next to your right knee. The provision for it, still exists in the LX's but there is no block connection/bulbs to hook up.
HTH's
TrophyHead
1,195
11
49
PA
Apr 16, 2004
  • Apr 16, 2004
Thanks guys I learn something new everyday on this site.
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
