  • SN95 4.6L Mustang Tech
Check Engine Light
  • Thread starter Thread starter Sick96Stang
  • Start date Start date Oct 4, 2004
Sick96Stang
621
Gilbert, Arizona
Oct 4, 2004
  • Oct 4, 2004
Went to autzone today to get the codes pulled because my check engine light has been going on and off lately. Its an o2 sensor Bank 2 Sensor 2. I know bank 2 is the bank in front of were the cats would be but it sensor 2 the one on the left or right side of my car? I have the MAC O/R H-pipe but I also have the MIL's on there. I dont think it is the MIL's that are bad because I have 2 MIL's and they are hooked up to both the sensors in bank 1. Neither of the sensors in bank 2 looked bad could it just be a loose connection or something?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Oct 4, 2004
  • Oct 4, 2004
you have it backwards. bank 2 is the drivers side bank. sensor 2 is the back sensor. you need to get MIL eliminators or have a tune where the rear O2's are turned off.
Sick96Stang
621
Gilbert, Arizona
Oct 4, 2004
  • Oct 4, 2004
I have MIL's on there already. They are on the back 2 sensors, do u think the MIL's went bad or is the wiring not right somehow or the o2 sensor went bad?
T
Thiel
  • Oct 4, 2004
Yea,just change the frount ones i got new ones n it made my car run so much better the first two control ur mixture n the back two check for emis- n to make sure the cars hot to burn the unburned gas, i had that same code i had wire in mils i pulled em n got the steeda ones they work but there huge
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Oct 4, 2004
  • Oct 4, 2004
dont mean to flame, but you cant read. he said the code is for sensor 2. sensor 2 is the back o2. more than likely changing out the front o2 will only cause his wallet to be $80 lighter. more than likely your MIL eliminator went bad.
HuskerCobra96
741
Overland Park, KS
Oct 4, 2004
  • Oct 4, 2004
Hold the phone here gentlemen. What is the actual code number your car is triggering? P0156? P0430? With the code, I can pinpoint the issue and give you the help needed to get this taken care of. I have some experience in this area...
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 5, 2004
  • Oct 5, 2004
you should also check if you ripped the wire that goes to theO2 sensor.... found out that was my problem.
D
d347h3
  • Oct 21, 2004
I am having the same problem, I have x-pipe and am throwing P0171. System lean bank 1. right now i have nothing on the front senors, and steeda mils on the bank ones. I am wondering if maybe one of my mils is bad. Thanks.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Oct 22, 2004
  • Oct 22, 2004
well that code is for the front passengers side sensor. what it says is that you are running lean. the rear 02's would not throw that code.
E
el_kid_1
738
Puerto Rico
Oct 22, 2004
#10
  • Oct 22, 2004
  • #10
Most likely your MIL eliminator has gone bad. But, if you tell us the codes, we will be in a better position to give a diagnosis.
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
