  • 1994 - 1995 Specific Tech
check engine light
  • Thread starter Thread starter drewzx3
  • Start date Start date Jan 17, 2006
D
drewzx3
411
Louisiana
Jan 17, 2006
  • Jan 17, 2006
I just got my car back running from changing motors and now the check engine light is on. The code is 332 insufficent egr flow detected. What all could be causing this?
MysteryMachine
1,835
Parkesburg, PA
Jan 17, 2006
  • Jan 17, 2006
broken vac line to the egr valve. mine throws that code like everytime I drive it. Its becaue my vac lines broke and i have then held together with a piece of rubber hose. Not sure if it can get cloged up inside or not
D
drewzx3
411
Louisiana
Jan 17, 2006
  • Jan 17, 2006
That sounds right. when i changed motors i changed to a trick flow intake and the egr vacume line was to short to reach so i had to get another one that was laying around the shop and it doesnt fit tight.
MysteryMachine
1,835
Parkesburg, PA
Jan 17, 2006
  • Jan 17, 2006
yeah when mine snaped it kinda smashed the ends and has gave me issues ever sense
HISSIN50
34
129
Jan 17, 2006
  • Jan 17, 2006
If you notice detonation, fix it ASAP.
Good luck.
D
drewzx3
411
Louisiana
Jan 17, 2006
  • Jan 17, 2006
I havent noticed any but I have only drove it a few miles.
95cobraguy
637
11
Concord, NC by way of LI, NY
Jan 17, 2006
  • Jan 17, 2006
if the hose checks out ok, hows the gasket? also maybe the egr tube has a pinhole or crack. just some other areas to look at.
KBCobra95
356
North Carolina
Jan 17, 2006
  • Jan 17, 2006
Just delete it and be worried no more, unless you have emmisions.
95cobraguy
637
11
Jan 17, 2006
  • Jan 17, 2006
thats really the best fix, i ditched mine and haven't looked back.
HISSIN50
34
129
Jan 17, 2006
#10
  • Jan 17, 2006
  • #10
I wouldnt personally dlete it unless I could turn off the EGR function in the computer.
That is just me.
D
drewzx3
411
Louisiana
Jan 18, 2006
#11
  • Jan 18, 2006
  • #11
I replaced the hose and the gasket is new.
HISSIN50
34
129
Jan 19, 2006
#12
  • Jan 19, 2006
  • #12
You can apply 5-6" hg of vac to the nipple on the EGR valve and watch the diaphram travel. A bad diaphram can cause it to not move much. Also one can remove the valve and clean it out (they coke up). This can also reduce the flow (the debris in there causes the inert gasses to bottleneck).
It takes 5 mins or so to remove the EGR valve (two bolts or nuts, the feed pipe [soak it in PB first] and the vac line. I think that is it).
Good luck.
D
drewzx3
411
Louisiana
Jan 19, 2006
#13
  • Jan 19, 2006
  • #13
Can someone post a pic of the vacume line that runs off of the egr valve and the others so I will know I have all of them in the right place.
MysteryMachine
1,835
Parkesburg, PA
Jan 19, 2006
#14
  • Jan 19, 2006
  • #14
Sure man i'll run out and try to get some now.Sorry I haven't got them to ya yet just got on the computer
D
drewzx3
411
Louisiana
Jan 20, 2006
#15
  • Jan 20, 2006
  • #15
I think I had a vacume line in the wrong place. I swapped two around and it has not came on since. thanks
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
