well my car is running ok but not great. the check engine light comes on and only goes off under conditions where the throttle is applied to accelerate. if i'm idling or just on the gas enough to keep it cruising then the check engine light comes on. so i had my next door neighbor check it since he has been a mechanic for some time and the codes he pulled was something about the MAP sensor being out of range but the O2 sensor was reading fine and basically everything else was reading fine. he brought home one of his computer devices to diagnose what was going on and he said he couldn't find what was causing the problem. the other thing is that sometimes when i am slowing down and pull out of gear into neutral the rpms hesitate to drop and when they do they either drop to about 800-900 rpms and then bounce to about 1500 and then drop back to 800-900 or it drops below the 800-900 to about 600 and then bounces and then settles back at 800-900. not sure why.
look it's been a long time since i've been on here and kept up with things and i really don't have a whole lot of time to research things but this mustang was my grandmas and she gave it to me and i would love to be able to restore it and get it to a condition worth doing the turbo mods etc which i wanted to do with my first 2.3 stang. unfortunately i got sideswiped by an SUV which dented the rear passenger panel right before the gas cap cover and then since the emergency brake doesn't like to work it rolled out of my drive way one day and rolled into a small brick wall which shifted the passenger front panel backwards so the passenger door scrapes that panel and makes an awful sound now. also the bumper has tears in it and the fiberglass framing inside the bumper was broken and the head light and the hood was dented.
basically my main concern is the integrity of the car. i am sure i can do minor body work, i'm not so sure about the dent from the SUV cause the repair places i took it to said they would have to pull that whole panel off to work on it etc. but besides all that the car has so many damn groans, moans and squeaks.
is the any hope?? or would i be better off getting a different stang all together? i would really like to one day drive it back to my grandma and show her how nice the car would be. she is very disappointed when i talk about it having problems and how it's in POS condition.
