check engine light
  • Thread starter Thread starter HOT MERC
  • Start date Start date Mar 19, 2011
HOT MERC
Racine Wi.
Mar 19, 2011
  • Mar 19, 2011
My car will not pass emission test because my check engine light is not working. Any ideas. Thank you. Bill
txredgt
1,343
33
69
Mar 19, 2011
  • Mar 19, 2011
Post in the tech section and get our car to autozone if you don't have a tuner to see what codes you are pulling. Also if you haven't had the car long and don't know what has been added aftermarket wise, it wouldn't hurt to crawl under the car and see if you have an off-road mid pipe as that will probably be your cause.
HOT MERC
Racine Wi.
Mar 20, 2011
  • Mar 20, 2011
engine light
Thanks I have a stock exhaust. The car passed every thing except there was no light. Taking it to dealer monday.
GDawg
1,469
Nevada
Mar 20, 2011
  • Mar 20, 2011
That light is controlled directly from the PCM as I can see. It's the PNK/LT GRN wire coming out of the PCM (terminal 2). Looks like the power is shared by the tach so if that's working then it's the ground coming out of the PCM...
btw, this should be in tech...
HOT MERC
Racine Wi.
Mar 22, 2011
  • Mar 22, 2011
Sorry Iam kind of new to posting. Someone removed the bulb for some reason. I took it to Ford dealer and they replaced the bulb for $199.00. It passed emission just fine.
GDawg
1,469
Nevada
Mar 22, 2011
  • Mar 22, 2011
The "ole missing $200 bulb" repair... I gotta get certified for that one!
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Mar 22, 2011
  • Mar 22, 2011
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
D
Theft light staying on car starts right up
  • dtarang
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 15, 2026
dtarang
D
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
G
2000 GT- Alternator not charging
  • grugug
  • Tuesday at 8:30 PM
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Thursday at 9:04 AM
squeak93
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
