  • 1994 - 1995 Specific Tech
checking for spark
  • Thread starter Thread starter legalize420
  • Start date Start date Oct 6, 2005
legalize420
1,541
South Florida
Oct 6, 2005
  • Oct 6, 2005
how do you do it?
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
  • Oct 6, 2005
What are you checking? Coil or plugs?
For the coil, use some pliars with rubber grips and hold it above the dist. cap where it plugs into and have someone spin the car over and look for the spark.
Same way for the plugs, pull the wire off of the dist cap, hold it above and check for spark.
What's the car doing?
legalize420
1,541
South Florida
Oct 6, 2005
  • Oct 6, 2005
engine turns but wont fire. i swapped in gt40s and an e cam and when i tried to start the car last night would not fire. stabbed dizzy at TDC with rotor facing 1.
legalize420
1,541
South Florida
Oct 6, 2005
  • Oct 6, 2005
i have spark from the coil and plug number #1 ( i stoped after #1 zapped me). im pretty sure i have fuel, i can hear the pump. what should i check next. when i did my intake swap months ago even though my timing was way off the car still at least started after stabing the dizzy. i am going to restab the dizzy later on maybe tomorrow because i moved it from TDC when trying earlier. i dont feel like going out there right now, but what should i look at next. i was thinking maybe the valvetrain. i used the stock rockers with stock pushrods. could they be bolted down too tight or maybe its the dizzy and timing?
1105
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
  • Oct 6, 2005
If you used the stock rockers and pushrods you might need to check your valvetrain like you said. The rockers are probably holding the valves open a little bit if you just threw them on and tightened them down. I forgot how to adjust pedistal mount rockers, but I believe you have to use shims under them until you get them adjusted right.. I think its supposed to be a 0 lash? I've only adjusted stud mount rockers before so I'm probably not much help.
When you spin the car over, does it sound like there isnt any compression? Like its spinning a lot faster than it normally did.
legalize420
1,541
South Florida
Oct 6, 2005
  • Oct 6, 2005
i hear compression after i try to start it
i called dbeck and he gave me some good info. he was original going to help last weekend but he got tied up. basicly the first time i tried to start the car it was still on tdc. i need to get the dizzy back to tdc and then remove the coil from the dizzy and bump the engine a tiny bit so its not on zero on the balancer like when i tryed to start the first time. i have to work tomorow so i will try it maybe tomorow or dbeck said he doesnt mind giving me a hand this weekend. we will see how it goes.
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
P
Resolved Spark plug location
  • Ptanner
  • May 17, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk May 18, 2026
Ptanner
P
J
Which cylinder is which? 3.8L 2004
  • joeybuddy96
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 24, 2026
joeybuddy96
J
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
M
Idle problem
  • miser143
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
