Checking the rear main seal?
  • Thread starter Thread starter Sicarius428
  • Start date Start date Feb 5, 2006
Sicarius428
2,085
Feb 5, 2006
  • Feb 5, 2006
Hello All. Is there an easy way to check the rear main seal without removing the bellhousing? I am about to install my T5 and was just thinking I should check that before I install everything. I have the clutch inspection cover off and it looks good so far... what am I suppose to look for? Thanks
Kevin
JBeezy53
559
Sacramento, Ca
Feb 5, 2006
  • Feb 5, 2006
Is there any oil coming from behind the flywheel?
Sicarius428
2,085
Feb 5, 2006
  • Feb 5, 2006
There is a drop haning off the bellhousing but I can trace it up the block and not the tranny... or so I think.
Kevin
bill302
2,131
alabama,gadsden
Feb 5, 2006
  • Feb 5, 2006
oil leaking if area between bellhousing and motor is dry(no oil) with no dirt build up (dirt sticking to oil) you should be fine but you should know if you had rear seal problems because it would leak in driveway don't know about you but i always inspect under my car for leaks periodiocally and i even have a piece of waterproof laminate i park my car over so i can tell if i have a leak in my gravel driveway.
bill302
2,131
alabama,gadsden
Feb 5, 2006
  • Feb 5, 2006
Kevin
need to be 100 percent sure it did'nt come from the rear seal if i wasnt 100 percent sure i would dig deeper until i was sure and if i still was'nt sure after getting to it and inspecting it i would replace it. good luck.
_jb_
808
Michigan, Berrien County
Feb 6, 2006
  • Feb 6, 2006
I thought my rear main was leaking, but it turned out it was the lower intake seal. If you have the tranny out you might as well take the 20 mins and remove the belhousing anyways to see what's up.
JBeezy53
559
Sacramento, Ca
Feb 6, 2006
  • Feb 6, 2006
Yeah whenever I have a tranny out I take that extra time to check the rear seal. Every mustang I've owned I've had to change the rear main seal.
HISSIN50
34
129
Feb 6, 2006
  • Feb 6, 2006
Just be forewarned that if you replace a seal that is actually not losing much oil, there is a chance that the new one will leak more.
Good luck.
Sicarius428
2,085
Feb 6, 2006
  • Feb 6, 2006
I unbolted the inspection cover and jimmied a screwdriver to take a look with a flashlight and it looked really clean in there. There isn't any oil on the back of the flywheel or inside. The oil is coming from elseware... I have heard horror stories about trying to be preventative in maintainance and causing an issue with the rear main seal. Knowing my luck... that would be the case. Thanks for the replies.
Kevin
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Feb 6, 2006
#10
  • Feb 6, 2006
  • #10
Ain't broke don't fix it mentality can definately apply to the rear main seal. If all appears OK then I would not dive into the project...several people have replaced perfectly good seals when the problem was something else completely. I was VERY close to pulling mine appart...problem ended up being an oil pan leak, a little inspection time saved me a HUGE headache.
Sicarius428
2,085
Feb 6, 2006
#11
  • Feb 6, 2006
  • #11
Seriously. Thanks for the help guys.
Kevin
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
