  • SN95 4.6L Mustang Tech
Clean out the TB ?
  • Thread starter Thread starter Killa
  • Start date Start date Nov 30, 2007
Killa
1,006
56
49
Nov 30, 2007
  • Nov 30, 2007
Back then when im doing PI intake swap, I did spray load **** of card cleaner on TB cause I saw it was dark black stuff ( I driving import and if you clean out the TB it will help car idle and run alot better ). I dint knew those black coat is there for a reason, I clean it out completely . My car ran and idle fine now, but its bad for the engine ? do i need new TB ? thanks
d98gt
4,505
59
204
SE Texas
Nov 30, 2007
  • Nov 30, 2007
The black isn't there for a reason?
You'll be fine
2000fordstanggt
404
Westland, MI
Nov 30, 2007
  • Nov 30, 2007
ok im confused
hotmustang331
2,967
Bastrop,TX
Nov 30, 2007
  • Nov 30, 2007
The black stuff is there for a reason?
Soooo what reason might that be anyways?
G
guitarpnk99
17
Moline, IL
Dec 1, 2007
  • Dec 1, 2007
I think what he might be talking about is there is a sticker on the tb that says do not spray cleaner on the inside of it since there is a special coating or something like that. My 96 GT has a sticker that says something like that.
Killa
1,006
56
49
Dec 1, 2007
  • Dec 1, 2007
Yes.
DTNODYA
831
  • Dec 1, 2007
If your question is: I cleaned all the carbon-gunk out of my TB with carb cleaner, is it OK? Then the answer is yes, you are fine. FWIW, you can use 3M throttle body cleaner ... it works great and is "safe" to use on our TB's. Though I've never had any issues with regular carb cleaner anyway ...
Killa
1,006
56
49
Dec 1, 2007
  • Dec 1, 2007
so what that black coat in side out tb are for ? if I remember I clean the hell out of it and even use brush to brush all that gunk out.
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
Dec 2, 2007
  • Dec 2, 2007
Yes you aren't supposed to clean the TB's with carb cleaner due to the coating. Instead you should wipe it out or wash it off the engine
Killa
1,006
56
49
Dec 2, 2007
#10
  • Dec 2, 2007
  • #10
The TB was off the engine when Im cleaning it.
forum155pl
520
the 509
Dec 2, 2007
#11
  • Dec 2, 2007
  • #11
i sanded and polished mine.. it worked fine afterwards
fast97gt
1,082
north carolina
Dec 2, 2007
#12
  • Dec 2, 2007
  • #12
youll be fine man just make sure now that you clean it every other oil change (6,000 to every 7,000 miles). and you want to use air intake and throttle cleaner.
Killa
1,006
56
49
Dec 2, 2007
#13
  • Dec 2, 2007
  • #13
Im doing seaform before every oils change now ( over price but for me its worth it ).
Paint and Body Cowl Pan
  • jeremyzcook82
  • Sep 13, 2026
Fox 5.0 Mustang Tech Oct 3, 2026
Rcdgl
R
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
