Hey guys, I just finished putting on the clear fogs on my 02 Gt. Beautilful during the night, but sucked a** as night thanks to the 37.5watt 899 bulb. I looked through out the owners manual, and found that the fog circuit uses a 15amp fuse. After doing some research from aftermarket lighting like hella, and piaa, found that they also use 15amp fuses for their dual 55watt H4 bulbs. This info told me that it would be safe to install 50watt bulbs on the circuit. Also compared the wiring, and the wiring is about the same gauge. I just wanted to share this info incase anybody had any neg. comments/incounters about running higher wattage lights. I added 885 sylvania's (standard) and what a difference those 50watters made. I can see!!! The light pattern is 100% better then stock. I'm really not to concerned about the wiring / fuses, so much as I am worried about the tight quarters the bulbs are in, as in distance from the bottom and top of the reflector w/ the extra heat generated from the 50watt. If anybody has any good or bad thoughts, please let me know. If you would like pics, I'll try to attach em. If I had to do it again.....I would have done it 2 years ago.
