clear headlights
  • Thread starter Thread starter vobraman
  • Start date Start date Jan 8, 2004
V
vobraman
144
  • Jan 8, 2004
Has anyone changed their headlights to the new clear one's. if so which one's and have you had any wiring problems ? Any pic's would be great
monk302
742
New Jersey
Jan 8, 2004
  • Jan 8, 2004
I have changed mine out to those clear ones, what a world of difference let me tell you. I bought them from a guy on VMF several months ago and did the install in late August. I cannot believe the amount of light these new housings with quality bulbs throw out. They look similar to that very white headlights of the new cars. The only problem I have experienced is that the housings are slightly smaller than the old sealed beams so you really have to tighten them down and adjust them properly.
As for the wiring, that was a bit of a job. First I went out and found two 30 amp relays which was difficult for the specific ones I needed. I bought them for about 1.50 or something at Parts Express when some of stores around me wanted $15. From there, I wired them into the harness leading to the headlights. One to the low beams and one to the high beams. There is also a wire that I put to the solenoid. There is a chart somewhere on the net of how do this wiring which makes the job alot easier. It took me a little problem solving to get these lights to work but with a test light I eventually got the job done. I really like the end result, the only problem is that they make my stock fog lights look really dim. Sorry I don't have any pictures as my car is in my garage tucked away for the winter.
sn1per2121
  • Jan 9, 2004
i just bought some new lights for my 68 coupe. they're pretty sick. there is a big difference in lights. i didn't do any wiring they plug right in but when i put them on it was kind of raining so when i was driving they started blicking. i just put them on today. i don't know what to do if there is anyone who can help me.
here is what i got http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll? ViewItem&rd=1&category=33710&item=2451084312#ebayphotohosting
copy paste
rbohm
6,698
550
204
tucson,az
Jan 9, 2004
  • Jan 9, 2004
two things to check, one the headlight switch, and two the dimmer switch. if either is going bad you will have the blinking problem. the headlight switch is the likely culprit here. replace it, and also wire in a relay to run the lights to take the load off the switch itself.
88 Fox GT
1,674
Iowa
Jan 9, 2004
  • Jan 9, 2004
Aren't all headlights clear?
monk302
742
New Jersey
Jan 10, 2004
  • Jan 10, 2004
copy paste
Alright, the thing is with these new halogen headlights (I am assuming thats what you put in) it is easy to just plug in and forget about. That is until something starts happening like in your case as it now. First thing to check is the headlight switch. Replace that, for many of us have had to replace this, myself included because it will start to flicker on and off. That may solve the problem but since you are running these higher powered headlights
it maybe the reason it failed in the first place. People claim that if you just simply plug these higher powered lights it will burn up the wires possibly causing a fire which I can completely believe since after I put in the two 30 amp relays. The wires that run the juice to the headlights are so puny it is amazing they even brighten up the road. I will attempt to find a wiring harness for you.
V
vobraman
144
  • Jan 10, 2004
thanks, I am trying to find a place to order the lights from. Ebay has them for about 50.00 Mustang plus wants like 170.00. Trying to find out what is the difference. Hate to pay so much more for the same lights, just cause it has Mustang plus on the box. Any suggestions
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
Jan 10, 2004
  • Jan 10, 2004
Tri Bars
http://www.mustangdepot.com/OnLineCatalog/Accessories/tri-bar_headlights.htm
modmach1
239
Norway
Jan 11, 2004
  • Jan 11, 2004
I got clear tri-bar headlights on my 73/71 Mach-1 and it got a cool modern look
www.moldestuket.com
G
GaPonyFarm
663
Columbus, GA
Jan 11, 2004
#10
  • Jan 11, 2004
  • #10
Its your headlight switch. There is a built-in circuit breaker. A new switch should fix the problem.. A new harness would also be beneficial as the old, stiff, cracked wires are not as efficient as you might want, especially if you start adding new technology like electric fans, stereo & amps, A/C systems, etc.
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
R
Fox 1993 2.3L LX headlight harness
  • RubyRedNotch
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
AeroCoupe
Ferrite Chokes
  • jeremyzcook82
  • Feb 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 22, 2026
jeremyzcook82
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
