Only way to really be for sure on something like this is to get out some clay and check your clearance out.
Put some playdough or clay on top of a piston approaching TDC and manually bump the motor over. If the motor gets hard to turn, you should stop, unbolt everything and look at the putty. If you can see through the putty where the valve hits your in trouble. If the motor turns freely, take the putty out and measure the thickness of the depression with a caliper.
You don't want to trust the internet running that high of a lift. Or at least, I wouldn't
