  • SN95 4.6L Mustang Tech
Clutch Adjuster??
  • Thread starter Thread starter mustangmike23
  • Start date Start date Feb 26, 2004
mustangmike23
69
NJ
Feb 26, 2004
  • Feb 26, 2004
What does this do exactly? Does it shorten the distance that you need to depress the clutch? Please explain
Ruckus46Gt
385
Long Island
Feb 26, 2004
  • Feb 26, 2004
yea i was always wondering what exactly does it do i know it helps but how and why?
Cars&Guitars
41
Colorado
Feb 26, 2004
  • Feb 26, 2004
As I understand it, it prevents you from having to crawl underneath the car to adjust clutch cable. As it stretches (if that is a good term), you can adjust play in your clutch at the firewall instead. I have one with the double hook quadrant thing and like it. I dont know how to explain it but I have a better feel for the clutch now.
mustangmike23
69
NJ
Feb 26, 2004
  • Feb 26, 2004
bump
Cyberdavea
139
Orlando, FL
Feb 26, 2004
  • Feb 26, 2004
My friend has the exact same car I do... 02 GT... and his clutch pedal is soft like butter, and my is really stiff. Does an adjustable clutch cable have anything to do with how the clutch feels?? We both have stock clutches... etc... and I always wondered why there is a difference. I can shift his car a lot smoother too... could my cable not be adjusted properly?!?
AdRock
521
South Texas
Feb 26, 2004
  • Feb 26, 2004
The stock cable is self adjusting. So if you drive your car harder the clutch will tighten up and fell more stiff, then after normal driving it will adjust again and loosen up a little. For myself, the biggest advantage to this is at the track. You know that the clutch pedal is going to feel the same on every run.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
T
Drivetrain Take a look at this clutch pedal
  • TNmach1
  • Sep 18, 2026
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
WTB Wanted - Foxbody clutch pedal
  • TTSaleen
  • Aug 4, 2026
  • Want to Buy
Want to Buy Aug 6, 2026
General karthief
