Clutch Cable
  • Thread starter Thread starter Chairbornranger
  • Start date Start date Jan 14, 2009
C
Chairbornranger
  • Jan 14, 2009
I was downshifting today and heard my clutch cable snap. I had already ordered a clutch w/ a cable and was wondering how big of a pita it was to change the cable. I've changed clutches but never a cable so any info would be great
87foxstang
Cromwell, CT
Jan 14, 2009
  • Jan 14, 2009
cable is simple, 15 minute job. disconnect from bracket under dash and from clutch fork, route the new one through the fire wall and hook it back up and adjust. youll be fine if you have done a clutch
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 14, 2009
  • Jan 14, 2009
The clutch cable isn't hard if you are a short, skinny guy. :
If you aren't, be prepared to stuff 10 pounds of coffee an a 5 pound can or remove the driver's seat. When you remove the driver's seat, there is more room, but you will need to put some plywood over the seat mount studs that stick up from the floor. If you don't, they will definitely scratch up your back. Big hands don't help either...I have been told that it is much easier if you peel the carpet back from under the clutch pedal.
The binding common to adjustable cables is often due to misplacement of the adjusting nuts on the fork end of the cable. Both nuts should be on the back side of the fork so that the domed nut faces the fork and the other nut serves as jam or locknut to the domed nut.
Have fun and keep lots of Band-Aids handy – you may need them.
Nova
128
  • Jan 14, 2009
if you dont have an aftermarket quadrant now would be a good time to put one on...
its not to bad to do, easier than a throttle cable.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,238
2,942
224
Vass, NC
Jan 14, 2009
  • Jan 14, 2009
LMAO nah nah it's really simple... Listen, I'm a 6'3" 205lbs guy and here was my technique. Set the seat back as far as it would go, and lay the seat back too. Sit in the seat backwards and slide under the steering wheel. Make sure you have all the tools you need before you attempt this feat and make sure to stretch Your head will grind into the floor board as you are trying to do the work. If you can't tilt your steering wheel up ('90 or newer) then it's usually best to come at it from an angle outside of the car. Good luck. haha Take some video while you work.
Chris
Duncan McDougal
99
Gainesville, FL
Jan 15, 2009
  • Jan 15, 2009
When installing the aftermarket quadrant it is easier to just cut the pawl off then trying to break it, at least in my experience (damn nylon wouldn't break). You will need one of those hacksaw blade tools that is just a handle though. The fox3 is a nightmare to install an aftermarket quadrant in vs a newedge due to how the firewall is designed.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
