clutch diameter for an 87 w/ TKO
  • Thread starter Thread starter 87coupe50
  • Start date Start date Aug 4, 2008
87coupe50
105
WAYNESBORO, PA
Aug 4, 2008
  • Aug 4, 2008
I'm looking for a clutch. Done some searches and most say that the clutch is 10.5. Most places I've looked at show a 10.4 or 10.5. Is there any physical difference or are they one in the same? Bought the car with the Tremec already in there but I'm pretty sure it's a 26 spline. I was looking at this one but I don't want to waste money one the wrong one.
faststang90
522
baytown texas
Aug 5, 2008
  • Aug 5, 2008
u need to make sure u have the tko tranny but that is the right one if u have a tko.
u can get the car up and pull the drive shaft out and look at the drive shaft yoke if it has a 31 spline out then u have a tko. a stock one is 28 spline. i had a tko in my car years ago before they sold a kit. i had to buy a clutch for a chevy disc and use a fords pressure plate
87coupe50
105
WAYNESBORO, PA
Aug 5, 2008
  • Aug 5, 2008
It's a TKO 500. I just can't find any info on what size clutch to get for it. I've was told 10.5 and to get a Centerforce D/F 26 Spline, but all the listings show those clutches as being 10.4. Just trying to confirm that is the one I need.
MarcMonteverde
66
S@c-ToWn
Aug 5, 2008
  • Aug 5, 2008
if i were u id just pull the tranny out and make sure,
i have tremec tko also i went and bought the 21 spline because
it was the most common one they sold and my tranny was on there list
well when i get to the input shaft i had a 10 spline, so just because
save ur self the time and just make sure your gettin the right part
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Aug 5, 2008
  • Aug 5, 2008
I think the spline count is the more important thing to worry about
.1" is 2.5mm. Divide that by two and that's 1.25mm difference on the edge. That's like _ big
87coupe50
105
WAYNESBORO, PA
Aug 5, 2008
  • Aug 5, 2008
I was under the impression that they only came in 10 spline (standard) or 26 spline.
I can't believe the P.O. would upgrade the trans output and rear end to 31 spline and leave it 10 spline input.
faststang90
522
baytown texas
Aug 5, 2008
  • Aug 5, 2008
tranny
they have like 3 tremec
1) m-7003-r58w it has a 10 spline inlet and a 31 outlet it has a 0.68 5th gear
2) m-7003-r58c it has a 26 spline inlet and a 31 outlet, it has a 0.82 5th gear
3) m-7003-r58h it has a 26 spline inlet and a 31 outlet, it has a 0.68 5th gear
when i got mine they only had 2 types so doing the drive shaft would not work for u
87coupe50
105
WAYNESBORO, PA
Aug 5, 2008
  • Aug 5, 2008
thanks. is there anywhere inparticular i can look on the trans to find that number?
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 5, 2008
  • Aug 5, 2008
Dual friction isn't going to stand up to your car just so you know. If its a TKO 500 it should be 26 spline, and 10.5. 10.4 is fine also. Look into ram powergrips or spec clutches.
87coupe50
105
WAYNESBORO, PA
Aug 6, 2008
#10
  • Aug 6, 2008
  • #10
Why do you say that?
87coupe50
105
WAYNESBORO, PA
Aug 6, 2008
#11
  • Aug 6, 2008
  • #11
FYI.. Just got off the phone with a tech at centerforce. He said the DF161057 is rated at 500-525 Tq @ the crank.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 6, 2008
#12
  • Aug 6, 2008
  • #12
Because Ive smoked two of them both in under 3k miles around 475 rwhp. Called centerforce and they told me the DF is good for 350 rwhp, though the 4.6 models hold more for some reason.
87coupe50
105
WAYNESBORO, PA
Aug 6, 2008
#13
  • Aug 6, 2008
  • #13
Curious, where you using the DF161057? so what are you using now and how is it working out for ya?
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 7, 2008
#14
  • Aug 7, 2008
  • #14
Yea, just looked it up on summit looks like a dual friciton. I am using a ram powergrip HD right now and so far so good. Its good for 650 ft/lbs. The plain powergrip is good for 500 ft/lbs I believe. Also have the ram billet steel flywheel. Pedal is about the same as the centerforce a little bit on off like and rarely chatters.
87coupe50
105
WAYNESBORO, PA
Aug 8, 2008
#15
  • Aug 8, 2008
  • #15
Well, got under the car and found the tag for the trans... glad I did. It's#'s were TR3550-7 TCET4615 which is a 10 spline inlet. So now I've got to find a 10 spline clutch that will hold the power. Any recomendations?
EMW150
2,020
Roaring Spring,PA
Aug 9, 2008
#16
  • Aug 9, 2008
  • #16
Spec II
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 9, 2008
#17
  • Aug 9, 2008
  • #17
Yea put a 26 spline input shaft in it. 10 spline ones have been known to break with lower power levels then you. Esp if your planning on launching the car. Think I paid $250 or so for mine including the shims. Ordered it from hanlon motorsports nice place to deal with.
87coupe50
105
WAYNESBORO, PA
Aug 9, 2008
#18
  • Aug 9, 2008
  • #18
you can just change the input shaft? I'll have to look into that... how hard of a task is it?
Car has been launched plenty of times, best is a 1.502 60 Ft. with 8.5 in slicks. That was with the A-trim. Been to the track twice since installing the SQ trim, could only muster 1.58. Car has had several issues over the last couple months. I think I've just about got them licked, just have to figure out a couple of noises.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 9, 2008
#19
  • Aug 9, 2008
  • #19
Yea you can just change out the input shaft, its pretty easy friend of mine and I did it in about an hour taking our time. Just letting you know, it could last 5 years or it could last one more pass. 10 spline input shafts arent rated for much.
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
