  • SN95 4.6L Mustang Tech
Clutch fork moved????
  • Thread starter Thread starter GToddyT5
  • Start date Start date Apr 19, 2005
GToddyT5
553
Hamilton, NJ
Apr 19, 2005
  • Apr 19, 2005
I was replacing my broken clutch cable and I noticed the plate that covers the clutch fork had been partially pushed off. So anyway, I replaced the cable with a Ford cable (UPR cables suck btw, I went through two). I go to put the plate back on and it will not go. For anyone who has done it, obviously this plate is child's play to put on and take off. This leads me to believe that my clutch fork has moved somehow. Can this happen??? I also have a lot of vibration in my clutch pedal now.
twogts4us
4,188
12
79
Dunedin, FL
Apr 19, 2005
  • Apr 19, 2005
Can the clutch fork move? Sure - it's not really attached...when loose, it just sits on the pivot. I kinda scared myself when swapping the cable, but it should drop right back into place. Get back underneath there and be sure it's sitting properly...and adjust the cable while you're there. Do you have a firewall adjuster?
GToddyT5
553
Hamilton, NJ
Apr 20, 2005
  • Apr 20, 2005
should i wack it with a rubber mallet?
GToddyT5
553
Hamilton, NJ
Apr 25, 2005
  • Apr 25, 2005
up
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 25, 2005
  • Apr 25, 2005
take the cable back off and make sure the clutch fork is sitting right.. if not wack it back into place... then when you put the cable back on if it vibrates thats because the cable is WAY WAY WAY too loose... tighten the clutch and you should be ok...
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
