Clutch/Idle Problem
  • Thread starter Thread starter Hellfire50
  • Start date Start date Oct 2, 2011
H
Hellfire50
  • Oct 2, 2011
Hello,
I have a weird problem. When I have the clutch pressed in, the car idles at 15-1600RPM. When I press it into the floor (literally as far as I can) it idles at 900 RPM??? Any suggestions?
Thanks!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 2, 2011
  • Oct 2, 2011
See the "Surging Idle Checklist for help with all your idle/stall problems.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the fixes & updates. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
MyHoFoSho
100
Oct 3, 2011
  • Oct 3, 2011
this sounds like the exact problem i had with my car when i first bought it and i have been waiting to share my fix for about 5 years now. But let me ask you a question first does it only idle high when the clutch is pushed in. If it does this is how i fixed my problem, test and see if you have a ground at the TPS sensor. If you dont tap into the wire and ground it to the fire wall. But this is just quick fix. If that fixes it you will have to see why the ground went bad. I hope this helps and good luck.
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
