Clutch Quadrant
tderrick
312
I'm going to replace my old, worn out factory quadrant over the Holidays,
and was wondering what the most popular kit is...
I'm looking at both the Steeda & Maximum Motorsports units.
I like MM's use of a clutch cable that can be replaced by a Ford unit on down the line and also the clutch hight adjuster.
thanks again...
im using
im using steeda i like it no problems make sure its tight through the clutch fork and in where the cable sits under the black box by the trans i used two bolts because my cable came loose and got hung up on the quadrant and started to cut the cable but i like the steeda
I've got the MM quadrant here. It isn't installed yet but initially, I'm very happy with the construction and design. Overall, it's a very nice piece.
I see no reason why it won't perform as advertised.
I used BBK and I used FMS, I now use Maximum Motorsports and like how it works much better!!! The fit and feel of the MM parts are great. I was having a problem with BBK and FMS; they were striping, stretching the clutch cable. I would have to readjust the unit every day. Switching to MM, I haven't had to worry about it.
I also have the clutch position alteration kit from MM . Love it. It lowers the pedal by an inch.
