  • SN95 4.6L Mustang Tech
Clutch Replacement
  • Thread starter Thread starter DarkCheshire
  • Start date Start date Jan 19, 2004
DarkCheshire
10
DC
Jan 19, 2004
  • Jan 19, 2004
Well like so many of us I am finally going through the infamous "Throwout Bearing" problem and instead of replacing just the bearing I'm replacing the whole clutch kit. Now, after hearing the labor quotes for my area I'm thinking that I can do it myself...I have access to a garage and the necessary tools I just don't have the experience. So here comes the question...Is there anything specific that I need to do? Could you guys give any helpful advice to help me with this painful process? Thanks for your time!
C
claytucc3
825
Santa Clarita, Ca
Jan 19, 2004
  • Jan 19, 2004
Hey man it is pretty simple. The only things you will need other than the clutch is molly, I would replace the rear seal on the tranny just in case. You will need to remove the driveshaft mid pipe and tranny. Possibly the shifter I just took my handle off of the tri-ax. KNow the torque specs and have some loc-tite and a friend to help with the install and removal of the tranny. It shouldn't take you more than a day. The hardest part is that there is a bolt you cannot see on the starter that you will need a lot of little extentions to get from the front of the motor. Otherwise it is simple just takes time
DarkCheshire
10
DC
Jan 21, 2004
  • Jan 21, 2004
Thanks for the answer clay, do I HAVE to resurface my flywheel?...or can I simply turn it?
C
claytucc3
825
Santa Clarita, Ca
Jan 21, 2004
  • Jan 21, 2004
Yeah I meant turn it.
downsouthman1
643
Texas
Jan 21, 2004
  • Jan 21, 2004
Dark I absolutely wouldn't go the shortcut route & turn it as you may have problems in the future w/ the new clutch & for the price of the clutch make sure you do it right. Get you flywheel resurfaced.
DarkCheshire
10
DC
Jan 22, 2004
  • Jan 22, 2004
Thanks clay and downsouth, I appreciate your help.
C
claytucc3
825
Santa Clarita, Ca
Jan 22, 2004
  • Jan 22, 2004
Anytime
GTVertY2K
115
Arvada, Colorado
Jan 24, 2004
  • Jan 24, 2004
Make sure you have (2) 12" and (1) 6" extentions and (2) univeral joints. You will need them to get to the upper transmission bolts.
DarkCheshire
10
DC
Jan 31, 2004
  • Jan 31, 2004
I just wanted to thank you all again for your advice. We finished everything up friday night around 6'ish, and after 11 hours of work my Stang is running again! =) So thank you all for your advice!
C
claytucc3
825
Santa Clarita, Ca
Jan 31, 2004
#10
  • Jan 31, 2004
  • #10
No prob man...enjoy......
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
