Clutch safety switch
  • Thread starter Thread starter cjman15
  • Start date Start date Jul 29, 2004
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jul 29, 2004
  • Jul 29, 2004
When I had my T5 transmission swap done, the shop that did tha work never hooked up the clutch safety switch (clutch has to be depressed to start tha car, i think)... so when my car is in neutral, you can start it w/o pushing it in... since i still have tha same computer from when it was AOD... i dont see any connectors down by tha harness... anyway to hook it up? i know it can be kind of dangerous if it's disconnected liek that
thanks
drgn5.0
603
  • Jul 29, 2004
yeah you can hook it up, the plugs are near the pedals. although i'm not postive on which ones you use.
HISSIN50
34
129
Jul 29, 2004
  • Jul 29, 2004
im not conversant with what connectors and such are messed with in the swap. the clutch safety switch is the lower (IIRC) switch on the clutch pedal arm. it has a 2 terminal connector. the switch is a simple push button set up, on the back of the pedal arm.
all the switch does is allow currect to flow from the ignition switch to the starter solenoid (eventually). when the clutch is not pressed in, the switch is open; push the clutch and the switch closes and allows current to pass to the solenoid (if any of this helps you wire it up).
good luck.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jul 29, 2004
  • Jul 29, 2004
This system uses red wires with blue stripes - I have a color wiring diagram at:
www.veryuseful.com/mustang/tech/engine
Here is a pic of the connector that you need to use.........it comes with a jumper for automatics - cut the jumper and splice the wires through the clutch interlock switch....
DemonGT
871
51
49
Sparta,WI
Jul 29, 2004
  • Jul 29, 2004
is there a easy way to bypass the safty switch?
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jul 29, 2004
  • Jul 29, 2004
i dunno if you guys understand what i'm sayin... i can start tha car w/o depressing tha clutch... when its in neutral is pretty cool not having to get in and push it in to start it... but its very bad if tha cars in gear... i don't know where to connect it to fix that
drgn5.0
603
  • Jul 29, 2004
i believe tmoss just told you, didnt he?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jul 29, 2004
  • Jul 29, 2004
Yes I did - maybe he didn't see it, but it doesn't get any more explicit that that.
HISSIN50
34
129
Jul 29, 2004
  • Jul 29, 2004
oh Tom, i think if you posted some pics of you pointing out the wires, while wearing, say, a .............. ah nevermind - you were explicit enough.
CJ, with no switch on the car, as you are now, it will start. the switch creates the added safety feature. if you run w/o one (or had one and bridged it), you can start w/o pushing the clutch...... does that help any?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jul 29, 2004
#10
  • Jul 29, 2004
  • #10
You wouldn't want to see that....
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jul 29, 2004
#11
  • Jul 29, 2004
  • #11
Yep, got'cha
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
