clutch slip
  • Thread starter Thread starter skywalker
  • Start date Start date Mar 28, 2004
skywalker
733
Pensacola, FL
Mar 28, 2004
  • Mar 28, 2004
I put a T-5 in my '68 coupe in january. The clutch has slipped since day one. I checked to make sure the bolts were tight and that there was no grease ont he flywheel and such. Any ideas?
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Mar 28, 2004
  • Mar 28, 2004
No play in the throw out bearing?
Clutch linkage adjustment would be a good place to look.
PB
skywalker
733
Pensacola, FL
Mar 28, 2004
  • Mar 28, 2004
Got a cable clutch and I've adjusted it a good bit...but it slips in every gear...particularly bad in 5th. It's slipping to much for a cable adjustment. Throw out bearing is good as far as i can tell.
pabear89
2,126
Mar 29, 2004
  • Mar 29, 2004
How much Free Play is in the clutch?
If the Throwout bearing is not completely backing off the pressure plate
then it could be your slipping problem.
PB
skywalker
733
Pensacola, FL
Mar 30, 2004
  • Mar 30, 2004
Not alot of free play. I don't have to press the clutch much to disengage it.
pabear89
2,126
Mar 30, 2004
  • Mar 30, 2004
There's your problem.
your petal should travel 1-11/2 inches before you have bearing pressure on the plate.
readjust your linkage.
PB
skywalker
733
Pensacola, FL
Mar 31, 2004
  • Mar 31, 2004
Hot damn! It worked! ooh-rah!
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
G
1967 mustang 9" Limited slip issue 28 spline
  • Gint
  • Jun 8, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 8, 2025
Gint
G
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
