  • 2005 - 2009 Specific Tech
CMCV delete install?
  • Thread starter Thread starter SpartaPerformance
  • Start date Start date Sep 19, 2007
1 of 2 Next Last
SpartaPerformance
2,517
61
89
Long Island NY
Sep 19, 2007
  • Sep 19, 2007
Anybody attempt this? Thinking about Ford or Steeda units, do they come with all necessary hardware like gaskets? Any good "how to" articles out there?
ScottM
219
Little Rock, AR
Sep 19, 2007
  • Sep 19, 2007
Sending PM now with a link on a write up. It's hosted on another board, or I would link it directly here.
I did mine though and it's a piece of cake. You reuse the old gaskets off of the ones you take off the car. There is no hardware or anything, basically you reuse everything you take off if I'm not mistaken.
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Sep 19, 2007
  • Sep 19, 2007
Yup, really simple. I'm assuming you were sent the TacoBill instructions. If so, follow those to the T and it'll be a cakewalk.
AquaTeen2004
Georgia
Sep 19, 2007
  • Sep 19, 2007
Would you send me a link of the article? thinking about doing this in the future.
K
kkdoughboy
212
Pennsylvania
Sep 19, 2007
  • Sep 19, 2007
Yes I agree, the install was very easy following tacobills very detailed installation instructions. I hope someone has sent them to you. Just make sure you have a custom tune for the cmcv removal. My SCT Livewire had an user adjustable option to remove this but when I tried to do this it didnt work. I was unable to drive the car until I got my updated tune from Brenspeed. Have fun with the install.
ScottM
219
Little Rock, AR
Sep 19, 2007
  • Sep 19, 2007
Yep, it was TB's write up. I did the same, followed them exactly and it couldn't have been easier.
ScottM
219
Little Rock, AR
Sep 19, 2007
  • Sep 19, 2007
Say please!
Just kidding, PM sent.
AquaTeen2004
Georgia
Sep 19, 2007
  • Sep 19, 2007
thanks bud
L
lusecannon
  • Sep 20, 2007
Can someone email me the article to josh.luse@verizon.net?
F
french2812
89
Olympia, WA
Sep 21, 2007
#10
  • Sep 21, 2007
  • #10
Ford does not sell delete plates any more so Steeda is your best bet. They have two sets, low priced and not low priced. Not sure of the difference you will see.
lightblade
366
Sep 26, 2007
#11
  • Sep 26, 2007
  • #11
I am installing them today, finally got my email tune for the deletes from brenspeed, i am using the directions that came with the plates, but if someone could pm me the link to the installation write up that would be great. Thanks
lightblade
366
Sep 26, 2007
#12
  • Sep 26, 2007
  • #12
Help!
I have the brenspeed tune for the cmcv delete plates, can I remove the cmcv motor from the intake or do i just leave it there plugged in???? Would like to just remove the control motor and arms but then there would leave that wiring plug is this ok?
lightblade
366
Sep 26, 2007
#13
  • Sep 26, 2007
  • #13
Anyone??? I've decided to remove the cmcv control motor from the intake, hope this works.
DarkFireGT
692
10
89
East Moline, IL
Sep 26, 2007
#14
  • Sep 26, 2007
  • #14
PM sent
K
kkdoughboy
212
Pennsylvania
Sep 26, 2007
#15
  • Sep 26, 2007
  • #15
Sorry for the late reply. You can remove the motor assembly entirely as you did and ziptie the unused connector out of the way.
K
kkdoughboy
212
Pennsylvania
Sep 26, 2007
#16
  • Sep 26, 2007
  • #16
Let us know what you think of the performance after this install. I have my opinions I'm curious to hear yours. Thanks, Chris
lightblade
366
Sep 26, 2007
#17
  • Sep 26, 2007
  • #17
Yeah, thats what I did, I removed the motor and actually removed the plug( it goes from the motor to a connector at the back of the intake a lil higher up, I disconnected it there and removed about 8 inch of plug wire, without cutting or ziptying, and now there is nothing to get in the way.) Ummm just did a quick 5 min test drive and holy crap!!!!! I feel gains everywhere even down low but especialy higher up. The road by my house is alittle uneven/bumpy and i went wot in 2nd and the tires were just chirping everytime i hit alil bump or groove, crazy!!
I think it also helped to get the custom brenspeed email tune, because my tune i had was just for my cai, and I have done lots of other mods since then(tb, full exhuast, coilpacks and plugs, udp). All i can say now is WOW, and Im going for another teste drive . I also scheduled for a dyno session on friday to see what this new tune, and deletes plates made!!!!
K
kkdoughboy
212
Pennsylvania
Sep 26, 2007
#18
  • Sep 26, 2007
  • #18
Good to hear dude. I have similar mods to my ride and my cars at the dyno as we speak. Its getting Steeda UDP's and then I basically have all bolt ons. I just purchased a Spydershaft that I'm gonna install as well. Next step is cams, then heads, then Kenne Bell or Magnacharger. I hope to get it back sometime tomorrow with good numbers I will post then. Later man Have fun
lightblade
366
Sep 26, 2007
#19
  • Sep 26, 2007
  • #19
It seems like you have the same basic plan I have. A lil different though. I am waiting on my lakewood watts link(backorder) so i can do my massive suspension overhaul. Sitting in the garage: ford racing k-springs, bilstein hd shcoks/struts, maximum motorsports caster/camber plates, motoblue billet aluminum lower control arms with relocation brackets, and j&m upper control arm, and of ocurse the watts link. Once all that stuff is installed I am doing heads/cams and forged internals at the same time.(manley h-beam rods, 17cc diamond pistons, feder mogul rings and all arp hardware) Crower stage 2 cams with comp beehive springs and steel retainers, and either the the ford racing cnc 3V ported heads, or find some takeoff 3v heads and port and polish them myself. After that goes in a spydershaft and Mcleod rst twin disc clucth and aluminum flywheel. Then 62lb injectors, twin gt40 fuel pumps, aeromotive fuel rail kit, and a procharger F1A running at 18-22 lbs of boost. Then maybe later a beefed up rear end and some sticky tires.
K
kkdoughboy
212
Pennsylvania
Sep 26, 2007
#20
  • Sep 26, 2007
  • #20
**** dude I almost got a semi. That is awesome. You know your stuff and my bro has a procharged 01 GT Conv. The prochargers are nice stuff but I want that cam and head growl along with the whine of an old school kenne Bell or a Magnacharger. Either way we both have a plan and a mission. Have fun this fall and winter with all the cool installs. Later bro
1 of 2 Next Last
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
