Coast Driveline Aluminum Driveshafts $589.99 NOW SHIPPING!
Now shipping Coast Driveline Aluminum Driveshafts for $589.99 to the door!
PM me if you're interested or give us a call at 610-497-5776 or 3736 and ask for CR!
- APD Performance
This will fit...
You will have to check your pinion angles, to ensure that they are proper.
Here is what needs to be done for it to clear:
Vehicles Dropped Approximately 0-2":
Near the rear of the driveshaft tunnel, there is a bolt holding on the ebrake cable and bracket. Relocate the bolt and bracket approximately 1.5" AWAY from the driveshaft tunnel. That's all!
Vehicles Dropped Approximately 2+"
The modification above must be done, and in addition there are two spots that need to be massaged. One is right near the ebrake cable, and you'll find a 2" by 3/8" wide lip. Simply bump that down flat, and you're done. There is a second spot in the middle of the floor tunnel. There is a stamping approximately 3/4" x 4" wide. Simply bum that down flat, and you're done.
90% of people will only need to do the ebrake cable relocation, and check pinion angle. That will be plenty sufficient!
Thanks for the interest!
APD Performance
