  • 1994 - 1995 Specific Tech
Cobra Calipers
  • Thread starter Thread starter ProjectoStang
  • Start date Start date Oct 29, 2005
P
ProjectoStang
80
  • Oct 29, 2005
I am interested in using cobra front and rear brakes. My question is: are the GT and Cobra calipers the same?
Are the cobra calipers single or dual piston types?
94CobraPace
907
Houston, Tx.
Oct 29, 2005
  • Oct 29, 2005
The GT & Cobra calipers on front are not the same. The Cobras use a 2 piston PBR caliper. Cobra rotor is 13".
The Cobras & GT use the same caliper in the rear, but the Cobra uses a vented rotor in the rear & is larger. Cobras use a different brake pad due to the vented rotor.
LoudToy958
435
Bremerton, WA
Oct 29, 2005
  • Oct 29, 2005
No, front cobra calipers are dual piston where the GT calipers are single. Also, the cobra front rotors are 13", and the GTs are not.
The rear setup .....ah, I see someone already got it. The correct info is above......
P
ProjectoStang
80
  • Oct 29, 2005
I was also reading that the only diff in the rear is the bracket the caliper bolts to. Do you guys know anything about that?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Oct 31, 2005
  • Oct 31, 2005
The bracket on the axle is longer, giving more room for the bigger rotor. Otherwise, the caliper and its bracket (the part the brake pads sit in) are the same. According to a website or two, you may need to use a file to add a bit of clearance to the caliper bracket. Just check if the rotor in the rear rotates freely, and how close the rotor is to the bracket. Use a metal file to add clearance in the bracket as necessary.
There's a Ford kit that has all the extra pieces you need for the upgrade: M-2300-M. Or you can piece it all together from a junkyard.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
A
S197 2 piston front caliper dimensions
  • AussieDavid
  • Mar 26, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 26, 2026
AussieDavid
A
