Hey guys, i've got myself a weird situation here. I just finished rebuilding my rearend, and repainting my whole motor, so i had it all torn apart. While apart, i checked the normal stuff like the plugs, gasket surfaces, vac hoses and such, and it was all good. I put here together minus the smog pump(left it in the extra parts pile
) and it ran perfect for over a week.
Then i got some gas(93 as always) and drove to work. On the way home, it started to stumble and stutter, it was raining so i was going slow but it was noticeable. Now i go to take the car out and this thing is chugging like a damn train! It is hesitating sooo bad, aslong as there is load on the motor, she's limp. Idles crappy, motor shakes like ricer at FunFordWeekend. What's going on?
So for a quick history.
-Has new pip spring 08
-Has ne ignition module spring 08
-Has new plugs
-New msd cap n rotor
-Fresh fluids
-Clean MAF and IAC
-Timing at 14
-FP at 38
Stockish motor, just boltons.
So what do you think?!!!!
I'm thinking swap the plug wires(these are all low mileage tho), and i only had time to throw 1 new O2 sensor in a while back, so ill throw the other in. Perhaps a vac leak??I'm lost fellas
-Has new plugs
-Fresh fluids
-Clean MAF and IAC
-Timing at 14
-FP at 38
