  • SN95 V6 Mustang Tech
CODE 1413 - Any Ideas???
  • Thread starter Thread starter phjohnso
  • Start date Start date May 6, 2005
P
phjohnso
  • May 6, 2005
I just got my 2000 convertible dropped off last night and azone scanned a code 1413. Can anyone tell me what I am in for to fix this and about how much?
thanks in advance everyone.
sincerely
pj
G
Gr0und_Fault
113
  • May 6, 2005
Well, http://www.obdII.com has the code listed as being: "Secondary Air Injection Monitor Circuit Low Input". I don't exactly know what you would look for with that code, but I personally would start checking out the area around the MAF.
P
phjohnso
  • May 10, 2005
as a followup to my original post - the code was caused by a faulty gas cap. I ordered one today from ford and will install it in a few days - after that the code will go away. The problem was the gas cap was not venting and when I went to close it - the cap would not click after is was closed all the way. I hope this helps someone else out there.
sincerely
pj
P
phjohnso
  • May 26, 2005
oh well - the gas cap replacement didn;t work and the code came back - has anyone out here fixed this problem yet???
sincerely
pj
get your free webpage counter at http://www.atflash.com
9
93Stang23
38
  • May 29, 2005
I've got this same code on my car, I want to try & clean my MAF sensor and see if that does anything. I got the code read and it said it was an auxiliary emissions control. I really want to get this problem fixed within the next few days.
P
phjohnso
  • Jun 1, 2005
this is a weird problem - let me know if you get it fixed
stargate160
40
  • Jun 1, 2005
phjohnso, did you reset the computer after you replaced the gas cap?
P
phjohnso
  • Jun 2, 2005
Thanks for asking - I did reset the error code only to have it come back a few hours later.
38stang
357
VA
Jun 3, 2005
  • Jun 3, 2005
It has nothing to do with the gas cap or the MAF.
It has to do with the air pump and or sensors that are associated with it. It is located in the right front fender.
9
93Stang23
38
#10
  • Jun 3, 2005
  • #10
This may sound dumb, but what is the air pump??
38stang
357
VA
Jun 4, 2005
#11
  • Jun 4, 2005
  • #11
It pumps air in to the exhaust system to help burn off unburned fuel.
9
93Stang23
38
#12
  • Jun 6, 2005
  • #12
So how do I fix this problem? The SES light is startin to get annoying, especially at night. Also, with this problem would I be losing any power or does it not really affect anything?
38stang
357
VA
Jun 6, 2005
#13
  • Jun 6, 2005
  • #13
It’s probable the air pump it’s self. But I can’t be sure with out seeing it.
P
phjohnso
#14
  • Jun 9, 2005
  • #14
I was starting to think it may have been the air pump and just looked and saw it was there. I'll try a JY piece but first it has been suggested that I unplug it and plug it back in to see if that may just fix it.
38stang
357
VA
Jun 11, 2005
#15
  • Jun 11, 2005
  • #15
It's just an electrical fan motor unplugging and reconnecting it will not fix it. If it's bad it will have to be replaced.
AndyG47
Jersey
Jun 12, 2005
#16
  • Jun 12, 2005
  • #16
93Stang23 said:
...The SES light is startin to get annoying, especially at night...
put a piece electrical tape over the light till you get it fixed.
I did the same when my car came back with a code "P1408 EGR Flow rate out of range. Insufficient flow" turns out the DPFE sensor went bad.
P
phjohnso
#17
  • Jun 15, 2005
  • #17
as a followup to my code 1413 trouble - I found the problem - the wires in the power plug to the air pump were corroded and dripping thick rusty water. I am going to get a junkyard air pump with a piece of the connectore and harness attahed and splice it into my existing harness. What a mess...
sincerely
pj
D
2021 GT p2015
  • danp1983
  • Jan 20, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 20, 2026
danp1983
D
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
