Code 34
  • Thread starter Thread starter 905.0GTford
  • Start date Start date May 3, 2005
9
905.0GTford
10
  • May 3, 2005
What caused this code. My car is idling up and down real quick, it is only by a couple hundred rpm but it set this code 34, which my book states "canister or egr valve control circut or EVP voltage to high" thats 3 things so how do I know what one is bad. I replaced the egr position sensor a while back could the egr valve be bad now
G
gt90stang
568
  • May 3, 2005
It's probably the valve since you already replaced the sensor. Mine just threw a code 34 last night and died on me. Tryed a rolling restart and it wouldn't run, had to pull over turn the key off then it started and ran fine. So I ordered both the sensor and valve, don't want that to happen again!
Don
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
