The car, (91 GT mostly stock) has a bad stumble during idle. I might have imagined it but I think it got worse when I had the engine mounts replaced. I'm sure it's not just more vibration because of the energy suspension mounts, the engine actually stumbles and bucks like it's missing or running out of fuel.
I pulled the code 49, which seems to be distributor related, and changed the rotor and cap. This helped it smooth out some but the stumble is still there. Changed out the sparkplugs, same thing. Smoothed out a little more, but under idle it stumbles and bucks bad, this stumble seems to go away completely when given some gas.
You guys ever run across code 49, any tips? I did a search on here but didn't find any threads with for this specific code.
TIA
TIA
