  • 1994 - 1995 Specific Tech
code 511
  • Thread starter Thread starter NIN
  • Start date Start date Sep 1, 2004
NIN
452
moorhead MN
Sep 1, 2004
  • Sep 1, 2004
will the cpu throw this code with a chip intalled, or does this mean that my chip or cpu is bad?
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
  • Sep 1, 2004
the chip overides some funtions, thus setting this code.
NIN
452
moorhead MN
Sep 1, 2004
  • Sep 1, 2004
Lately I have had a problem with stalling and at the same time my speedo doesn't work. When you first try to start it, it will stumble and die. The Second time it will start right up. If you let the fuel pump prime it will start right up. does this sound like my pump is failing. Or other fuel problems.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 1, 2004
  • Sep 1, 2004
511 means permanent Read Only Memory (ROM) test failed. It may be the chip causing this like chrismillion mentioned I would pull the chip out and clear the codes by disconnecting the battery then try pulling any codes. If the code still pops up some thing is wrong.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 1, 2004
  • Sep 1, 2004
This does sound like the fuel pump is unable to hold fuel pressure. Get a fuel pressure gauge and check your fuel pressure.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
M
Ecm program
  • Maccurley
  • Sep 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 7, 2026
Maccurley
M
2001 GT stuck in 2nd
  • 01gtslider
  • Jul 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
01gtslider
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
