  • 1994 - 1995 Specific Tech
code 542 real or ghost?
  • Thread starter Thread starter saleener94
  • Start date Start date Jan 17, 2008
saleener94
153
Compton,CA
Jan 17, 2008
  • Jan 17, 2008
Hi guyz. I'm getting code 542 after replacing fuel filter and using inertia switch to shut off fuel pump. I also just put my catted h-pipe back on for smog. (542=fuel pump secondary circuit open or grounded. I cleared it with my scanner but i'm worried it might come back. Is this normal to give code 542 after shutting off fuel pump this way? Car is running fine. And will it affect smog check even though CEL is off?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 18, 2008
  • Jan 18, 2008
A lot of the time (if not most), it's just a ghost code. The fuel pump relay might have had a slight delay when latching, or even could have been caused by the inertia switch? If you have a 5 speed and stalled it at all, I believe that has been known to cause the 542 as well. I wouldn't lose any sleep over it.
saleener94
153
Compton,CA
Jan 18, 2008
  • Jan 18, 2008
Thanx Stang. I feel better knowing that its common. I'll read the codes again just to see if it's back.
BlownFiveLiter
18
108
Chicagoland
Jan 18, 2008
  • Jan 18, 2008
It should remain until you clear it out, but if it doesn't return, it probably just was a ghost code.
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
