Doesn't sound like you need to check any wiring right now.
Spark tester on the cheap: Take an old plug and set it with the threads sitting on the upper intake. Pull a plug wire off a cylinder's plug and install the plug wire into your spare plug. Now test spark. Using a spare plug allows you to see the quality of spark over the correct gap and it's cheap.
If a spark is anything but nice and blue, there are issues. A spark should look awesome at 1 ATM, considering that normally it's being suscepted to a lot of pressure, turbulence and media.
I would not forget about that code but I would monitor it and see if it reoccurs.
Good luck.
