Code 94/44 AGAIN!
  • Thread starter Thread starter Walternator
  • Start date Start date Jun 8, 2010
W
Walternator
37
Jun 8, 2010
  • Jun 8, 2010
I have a 90 LX, 5.0, that has had a 94/44 error code for a couple of months. I think I've done all the diagnostics correctly, but I just can't solve this one. I've replaced the smog pump because it had a bad bearing. I've tested both solenoids during a KOER test and both have voltage switching during the test. Both are switching vacuum. If I disconnect the large, black hoses, I find lots of air coming out of the pump and that it switches at both valves during the test. Everything appears to be operating correctly. Out of exasperation, I changed the O2 sensors in the hope that they were not detecting the air flow. No improvement. I'm out of ideas. Can anyone help? jrichker, are you out there? I sure could use your expertise.
Many thanks!
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jun 8, 2010
  • Jun 8, 2010
Check the cross over tube at the back of the heads for a blockage, or build up. Same for the ports in the heads.
Reactions: Mustang5L5 and BlakeusMaximus
W
Walternator
37
Jun 9, 2010
  • Jun 9, 2010
Thanks for the suggestion, Joe. I'll check.
L
Low86GT
1,724
San Jose, CA
Jun 11, 2010
  • Jun 11, 2010
The 44 and94 are a very commen problem. The carbon build up in that cross over can get hard as a rock. Last time I cleaned one I started with a punch and a hammer then started spaying stuff in to let it soak.
W
Walternator
37
Jun 13, 2010
  • Jun 13, 2010
Looks like you were right, Liljoe. That pipe was full of crud. It took me a couple of hours to get it cleared to a point that I could pass air through it.
It got rid of my 94 code, but I still have the 44 code. Any more ideas?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 14, 2010
  • Jun 14, 2010
Codes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks.
Revised 28-Oct-2009 to correct code definitions and operation.
Code 44 RH side air not functioning.
Code 94 LH side air not functioning.
The computer uses the change in the O2 sensor readings to detect operation of the Thermactor control valves. When the dump valve opens, it reduces the O2 readings in the exhaust system. Then it closes the dump valve and the O2 readings increase. By toggling the dump valve (TAB), the computer tests for the 44/94 codes.
Failure mode is usually due to a clogged air crossover tube, where one or both sides of the tube clog with carbon. The air crossover tube mounts on the back of the cylinder heads and supplies air to each of the Thermactor air passages cast into the cylinder heads. When the heads do not get the proper air delivery, they set codes 44 & 94, depending on which passage is clogged. It is possible to get both 44 & 94, which would suggest that the air pump or control valves are not working correctly, or the crossover tube is full of carbon or missing.
Check to make sure that some one hasn't put a plug in the rear crossover tube mount on the cylinder head. The front ports are plugged, and occasionally someone will put the heads on and not notice the head is supposed to be installed with the crossover tube plug in the front.
Testing the system:
Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect
the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump
the pump's output to the atmosphere or pass it to the next valve.
The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or
to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the
vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes
from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheel well turn the
vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire.
Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to
the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground
necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side
will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the
vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel &
the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum
to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin
32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine
with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after
doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to
ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the
solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38
and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin
38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the
solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power &
ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
Typical resistance of the solenoid valves is in the range of 20-70 Ohms.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
See http://forums.stangnet.com/attachment.php?attachmentid=50636&d=1180923382 for a very nice drawing of the Thermactor Air System (smog pump) plumbing
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them
Reactions: 89Foxx!
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jun 14, 2010
  • Jun 14, 2010
Did you check the ports in the heads were the crossover bolts up? This is the passenger side code, so thats where you should be focusing on.
If all ports are clean, then the only thing I can see is a bad 02, which I have only seen in a few occasions. But I cant say for certain that it will fix your problem.
W
Walternator
37
Jun 16, 2010
  • Jun 16, 2010
Low86GT , jrichker, and liljoe07,
Thank you all for your suggestions and comments. I FINALLY got an 11/11 code tonight. I had to pull the crossover tube again and do some more plunging with a hanger. I had the tube all cleared out yesterday, but some loose crud must have plugged the passenger side up again after I put it back on. I've been fighting with this since March and couldn't be happier to have it fixed.
Thanks again,
Walternator
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jun 16, 2010
  • Jun 16, 2010
Good Job guy!
M
Mrg2783
5 Year Member
Apr 1, 2018
89
Newport Beach
Sep 18, 2018
#10
  • Sep 18, 2018
  • #10
Testing the system:
I have to fix these two codes for smog. 94 comes and goes. 44 is constant. Went through two smog pumps, new solenoids, valves, heads and cross over tube has been cleaned. I'm about to do the above tests.
I read it could also be O2 sensors. Which are years old. Is there a best way to test them in relation to these codes? I dont have a code 91 or 41 if that helps.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 19, 2018
#11
  • Sep 19, 2018
  • #11
My previous post was over 8 years old, and I have updated the 44/94 test path since then. See the updated version below...
Codes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Check for a clogged air crossover tube, where one or both sides of the tube clog with carbon.
Revised 21 Sep 2012 to correct the description of the process that sets the code and include Thermactor Air System diagram.
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them.
Code 44 passenger side air not functioning.
Code 94 driver side air not functioning.
The TAD solenoid/TAD diverter valve directs smog pump output to either the crossover tube attached to the cylinder heads or to the catalytic converters.
The O2 sensors are placed before the catalytic converters, so they do not see the extra O2 when the smog pump's output is directed to the converters or the input just before the converter.
The 44/94 code uses the O2 sensors to detect a shift in the O2 level in the exhaust. The smog pump provides extra air to the exhaust which raises the O2 level in the exhaust when the smog pump output is directed through the crossover tube.
When there is an absence of increase in the O2 levels when the TAD solenoid/TAD diverter valve directs air through the crossover tube, it detects the lower O2 level and sets the code.
Testing the system:
Note that the engine must be running to do the tests unless stated otherwise. For safety’s sake, do test preparation like loosening clamps, disconnecting hoses and connecting things to a vacuum source with the engine off.
Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve.
The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheel well turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The following computer tests are done with the engine not running.
vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Turning the ignition to Run with the computer jumpered to self-test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
The following computer tests are done with the engine running.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation with the engine running. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
R
Misfire at high rpm! Help
  • Ryanm2018gt
  • Jan 2, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 17, 2026
highplace11
H
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • dan50
  • Jul 18, 2026
dan50
