  • 1994 - 1995 Specific Tech
Code Puller
  • Thread starter Thread starter dlaul01
  • Start date Start date Jun 30, 2006
dlaul01
169
  • Jun 30, 2006
I have my old Code puller from my foxbody will it work on my 95 mustang and does it plug in the same place?
HISSIN50
34
129
Jun 30, 2006
  • Jun 30, 2006
It should work fine. The data connector is on the passenger side on a 94-95 GT (same place as a fox but mirrored).
Good luck.
dlaul01
169
  • Jul 3, 2006
i Pulled codes 3-1 and -43 like all egr codes.. could this be my idle problem or just caz i have no cats...
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 3, 2006
  • Jul 3, 2006
Having no cats won't affect your EGR unless your exhaust pipe has no provision for the AIR tube to attach. The codes would only be thrown for an OBDII car with no cats, because it has four oxygen sensors; two upstream of the cats, and two downstream to make sure the cats are working properly. The codes you retrieved have me somewhat boggled however. Did you pull two or three digit codes? 5.0 Mustangs in 94-95 should have three digit codes, unless your car was converted to the Fox A9L (or A9P) EEC module, in which case you would indeed have two digit codes.
HISSIN50
34
129
Jul 3, 2006
  • Jul 3, 2006
OH NO, this is the frankenstangin car, isnt it?
In the past, I had given up trying to figure out what mixture of components it had and tried to help on face value of posts alone.
Good luck.
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
Holiday Gift Tool Ideas
  • gkomo
  • Dec 17, 2025
  • Off-Topic Hangout
Off-Topic Hangout Dec 18, 2025
General karthief
