combo
  • Thread starter Thread starter stang9150
  • Start date Start date Jan 29, 2006
stang9150
142
Jan 29, 2006
  • Jan 29, 2006
got a 91 lx 5.0 with a 5 speed and 373 gears.i plan on adding a dan d t56 6 speed afr 165 heads,elderbrock upper and lower intake,elderbrock 65 mm throttle body,iam looking at something from comps cams maybe an extreme energy grind for the cam.iam not really sure so any inputs on cam recs would be great.with the 6 speed tranny i think 410s would work out ok i would imagine.what kind of power do you think this combo will make,anybody got any numbers with a similiar combo?thanks in advance
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Jan 29, 2006
  • Jan 29, 2006
sounds like a good combo, if you can do a custom cam.
It is only like 75 or so bucks more than an off the shelfer.
that should be a easy 300 the the wheels, unless the T56 eats up a lot more HP than the T5
gcwh02
515
pottstown, PA
Jan 29, 2006
  • Jan 29, 2006
sounds like a good setup, you are prob. going to want to run 24 lb inj. with that setup. Don't forget about your MAF get something like a 75-76 depending on what company, and maybe a 70mm TB would work better. good luck
I
IntenseBlue
946
  • Jan 29, 2006
Custom cam. It'll ensure you're getting the most of everything else in your combo.
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
