Comp Cams Roller Rockers?
  • Thread starter Thread starter 92stangg
  • Start date Start date Apr 4, 2005
9
92stangg
36
  • Apr 4, 2005
Ok i just picked up some 1.6 Comp Cam Roller Rockers with stud mounts and i was just wondering if theres any difference in installing them from the stock ones, do i torque them down the same or what....need a lil info thanks.
-Matt
8-7ttop
12
Houston, Tx
Apr 4, 2005
  • Apr 4, 2005
dude mustangs come with 1.6 rockers stock you should of went with 1.7's like the 93 cobra had, you just wasted your money, but ok. My 1.7's were straight bolt down not sure about yours though.
N
Na5.0HO
342
Michigan
Apr 4, 2005
  • Apr 4, 2005
For starters... You need stud mount heads for stud mount rockers unless u had them converted. Also, there is a specific way to tighten them envloving turning each cylinder to TDC.
9
92stangg
36
  • Apr 5, 2005
ya they are ready to go for the heads i have the studs torque down onto the heads but now i just need to know wat to torque the rockers down to
BeerElf
85
Hillsboro, OR
Apr 5, 2005
  • Apr 5, 2005
I've heard many different methods, but I found that generally 1/2 to 3/4 turn past zero lash is what most people seem to say.
hamonkeiser
290
Lancaster, PA
Apr 5, 2005
  • Apr 5, 2005
Depends on what kind of 1.6 rockers he got. Big difference between the Stock 1.6 & a set of the FMS or Crane 1.6 Rollers
N
Na5.0HO
342
Michigan
Apr 6, 2005
  • Apr 6, 2005
I agree with both BeerElf and Hamonkeiser
9
92stangg
36
  • Apr 10, 2005
does anyone know the torque rating i can do i find it easier than doing the half turn thing
9
92stangg
36
  • Apr 10, 2005
ttt
9
92stangg
36
#10
  • Apr 12, 2005
  • #10
can someone please help me with this.....i tried torqueing them to 20 lbs and i couldnt turn the motor over so then i tried the 1/2 turn and when i went to start it today it jus spun like there was nothing there and the exhaust popped.....anyone?????
289Mustang
11
#11
  • Apr 12, 2005
  • #11
Do this with the lifter on the base circle of the cam and you should be fine. This is assuming you have hydraulic lifters.
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
