Engine Compresion Ratio?
  • Thread starter Thread starter marks89
  • Start date Start date Oct 8, 2012
marks89
32
oklahoma panhandle.
Oct 8, 2012
  • Oct 8, 2012
whats the max compresion i can go one my 347 and run on premium unleaded? any imput would be great appreciated.
twistedwankel
200
Spring Hill, FL
Oct 8, 2012
  • Oct 8, 2012
I ran 10:1 on pump 93 octane unleaded with never an issue with a carbed very basic engine using no computer at all.
BUT your spark advance and computer controls will have alot to do with what you can do like a simple "knock sensor"? Modern computers allow up to 12:1+ with the right sensors. You building a diesel?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 8, 2012
  • Oct 8, 2012
Depends on the octane. My buddy was getting away with 10.5:1 on 91-octane a while back...but he had to back the timing down quite a bit to do so.
88LX5.Oh
1,442
205
94
Arkansas
Oct 8, 2012
  • Oct 8, 2012
My dad's drag car has 10:1 pistons with 60 cc combustion chamber heads and we've run it on 93 octane
Jace78
36
Keller, TX
Oct 9, 2012
  • Oct 9, 2012
It's tricky because you can time it back, then advance at the track with additives/race gas...
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Oct 9, 2012
  • Oct 9, 2012
i know a few guys running 11.5:1 on pump gas
Rick 91GT
Mustang Master
95
99
PA
Oct 9, 2012
  • Oct 9, 2012
11:1 is about the max I try to put in a street car with 93 octane....the cam is also critical as you can play with the cylinder pressure to make it work.
A typical 4cc flat top on a 54cc chamber head barely gets u 11:1
srtthis
5,129
1,666
204
Maryland
Oct 9, 2012
  • Oct 9, 2012
rick you tried doing anything really high since you guys have E85 right in town?
89stang1
Stroked and Juiced
730
234
74
nj
Oct 9, 2012
  • Oct 9, 2012
my 333 stroker is 10.7:1, Probe 4cc flat top pistons, runs on premium no problems RNH Performance built
marks89
32
oklahoma panhandle.
Oct 9, 2012
#10
  • Oct 9, 2012
  • #10
im actually gonna have to drop compression on it. its in my race car right now am gonna change heads and cam so i can run fuel injection and nitrous. it has 7cc domes. droping compression with thicker head gasket. will be aluminium heads. want to push as much compression as possible. thanks for the imput. mark
Rick 91GT
Mustang Master
95
99
PA
Oct 9, 2012
#11
  • Oct 9, 2012
  • #11
N20 loves compression.... what's the combo and specs? Thicker headgaskets can be an issue with increased quench.
D- they pulled all the e85....
srtthis
5,129
1,666
204
Maryland
Oct 9, 2012
#12
  • Oct 9, 2012
  • #12
Well that just blows
marks89
32
oklahoma panhandle.
Oct 10, 2012
#13
  • Oct 10, 2012
  • #13
i will be changing cams, ill call comp for custom grind. heads are set of ported svos and a trickflow track heat thats supposed to be ported. my 347 is a dartblock with eagle rotating assembly, i think throttle body and mafs is 75 also. 42 over injectors and 140gph fuel pump. bought street car and love it so much want to put my 347 in it and maybe sell race car or build bigger motor for race car.
marks89
32
oklahoma panhandle.
Oct 10, 2012
#14
  • Oct 10, 2012
  • #14
rick 91gt do you think keeping compression around 10.5 solve posible quench issue.
Rick 91GT
Mustang Master
95
99
PA
Oct 31, 2012
#15
  • Oct 31, 2012
  • #15
How many cc are the head chambers? Your staying with a 7cc dome?
marks89
32
oklahoma panhandle.
Oct 31, 2012
#16
  • Oct 31, 2012
  • #16
not sure yet will cc them then determine thickness of head gasket needed.
R
reldla1996
356
22
Dayton, Ohio
Oct 31, 2012
#17
  • Oct 31, 2012
  • #17
I'm running 10.6 on my 369 with AFR heads and 92/93 pump gas with no issues.
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
K
2024 gt premium. Water drips on garage floor mid car. Is this condensation? From exhaust? Any help would greatly be appreciated. Thanks
  • ksburn
  • Dec 5, 2025
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jan 25, 2026
Mustang5L5
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
