Compression #'s
  • Thread starter Thread starter QDRHRSE
  • Start date Start date Sep 20, 2004
QDRHRSE
1,590
Palmdale, CA
Sep 20, 2004
  • Sep 20, 2004
What kind of compression #'s do you guys get when you run a compression test....that is, if have have done one? List heads and cam too please. I'm seeing 145 with AFR 185's and an F Cam. Anybody else? Is this low?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Sep 20, 2004
  • Sep 20, 2004
Mine averaged 145 also with my stock cam (with sloppy 190k chain) and stock heads. Haven't retested since the P head install. My stock cam had valve events VERY close to the Crower 15510 cam.
HISSIN50
34
129
Sep 20, 2004
  • Sep 20, 2004
im one to believe it is a bit like two guys comparing dyno runs (even from the same dyno): the relative numbers you get are what matters - not absolute numbers. there are enough variances in gauges and methods (motor warm, at WOT, etc) to create deviation. as long as they are all close, i would not sweat it.
now if i totally missed the point of your posting - my bad.
good luck.
QDRHRSE
1,590
Palmdale, CA
Sep 21, 2004
  • Sep 21, 2004
Hissin-
No. You got it. It looked low and it got me thinking because the car is running like crap and I can't figure out why. Your absolutely right about everybody being different but I just wanted to see what the spread was like.
V
v8only
2,378
22
49
Sep 21, 2004
  • Sep 21, 2004
last time I ran a check on a healthy stock 5.0, I got around 150 all the way around, your #'s sound about right.
F
fost9508
131
  • Sep 21, 2004
What about compression from cylinder to cylinder, when I have done a compression test all the cylinders get a little bit diff numbers. What is the rule of thumb when review the compression test results. i.e. all the numbers should be +- 10 psi from the highest cylinder reading....????
thanks,
87'GTstang
1,025
  • Sep 21, 2004
thanks,
+/- 10 percent
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
