  • SN95 4.6L Mustang Tech
compression test results. post Headswap.
  • Thread starter Thread starter KJ Hoppus
  • Start date Start date Jun 5, 2004
KJ Hoppus
1,008
Elk Grove CA
Jun 5, 2004
  • Jun 5, 2004
well after finishing my pi headswap i read a few theads with people haveing low power number or slow track times. they did a compression check and found out that one of the timing chains were off. well i dont have any track times or dyno number, but i figured id check it out just in case.
my results:
driver side pass. side
195---195 192---191
198---195 192---196
200---200 195---197
201---204 194---199
i did each side twice just to make sure. anyway it seams like everything is ok. i am goiing to the track next saterday to see what happens.
KJ
H
HIGDON
241
Ft. Hood, TX
Jun 5, 2004
  • Jun 5, 2004
Hey, did you take your motor out to do the swap?? I saw that you had head studs and I was wondering since the bottom head bolts can't be removed from the head when it's in the car.
KJ Hoppus
1,008
Elk Grove CA
Jun 5, 2004
  • Jun 5, 2004
yes the motor was out.
H
HIGDON
241
Ft. Hood, TX
Jun 5, 2004
  • Jun 5, 2004
thanks
BlueStangGT
223
Oklahoma
Jun 6, 2004
  • Jun 6, 2004
195---195 192---191
198---195 192---196
200---200 195---197
201---204 194---199
KJ
That's nearly identical to the numbers after my swap. They all fell between 195 and 205.
KJ Hoppus
1,008
Elk Grove CA
Jun 6, 2004
  • Jun 6, 2004
good to hear.
M
Compression Test Results Surprising?
  • mcowing
  • Sep 23, 2017
2K
Fox 5.0 Mustang Tech Sep 24, 2017
General karthief
Results Of The Compression Test.....help And Thoughts
  • from6to8
  • Dec 26, 2013
2K
Fox 5.0 Mustang Tech Dec 27, 2013
from6to8
Compression Test Result with PI Headswap and Comp Cams262
  • 97GTSTANG
  • Oct 8, 2011
SN95 4.6L Mustang Tech Oct 10, 2011
97GTSTANG
T
Leak Down Test Results
  • TheUser
  • Oct 5, 2011
6K
SN95 4.6L Mustang Tech Oct 11, 2011
Lugnuts
Compression test results inside. . .
  • JungleJoe
  • Aug 13, 2011
Fox 5.0 Mustang Tech Aug 14, 2011
JungleJoe
