  • SN95 4.6L Mustang Tech
compression test results
  • Thread starter Thread starter jivepepper
  • Start date Start date Aug 13, 2005
jivepepper
776
Under a Sombrero. in WV.
Aug 13, 2005
  • Aug 13, 2005
I just finished my compression test. This is the result what does everyone think?
Back of engine
4=167 8=169
3=166 7=172
2=166 6=169
1=167 5=167
Front of engine
The test was done on a cold engine.
jivepepper
776
Aug 14, 2005
  • Aug 14, 2005
Ttt
billfisher
1,296
huntsville, AL
Aug 14, 2005
  • Aug 14, 2005
not too bad
your high to low is within 95%. seems ok balance.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Aug 14, 2005
  • Aug 14, 2005
looks good.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Aug 14, 2005
  • Aug 14, 2005
It looks fine.
jivepepper
776
Aug 14, 2005
  • Aug 14, 2005
Thanks I just wanted a second opinion.
R
registered
15
  • Oct 13, 2005
Hi,
Where can I get a compression test?
I was told by someone I could walk into Autozone and they'd do it, but they said they don't do compression tests.
Thank you,
Brent
hotmustang331
2,967
Bastrop,TX
Oct 13, 2005
  • Oct 13, 2005
Yep, that looks fine...good thing to do with a S/Cd motor.
You can go to autozone and buy a compression tester...pull your spark plug and crew in the line with gauge...and crank up the car. Some people just spin it over, but I like for the car to be running. Crank it up and go look at the gauge...note it, shut the car off and repeat with all cylinders. Be sure to put the plugs back in each one after your finished lol.
R
registered
15
  • Oct 13, 2005
lol, indeed. Man, I can do this myself!
Thanks for the reply.
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
Oct 13, 2005
#10
  • Oct 13, 2005
  • #10
hm, its been a while since ive run a comp test, but dont you need to disable the fuel system in order to run this test? when you start the car w/o the plug in the combustion chamber, youre dumping air and fuel into the chamber and its not getting burned i was taught to pull the fuel system fuse, and crank the engine no more than 5-6 times so you dont burn up the starter. note the guage while cranking. its been a good year since ive done one, but thats what i seem to remember
haneymotorsport
67
AZ
Oct 14, 2005
#11
  • Oct 14, 2005
  • #11
DerekstangGt-
You are correct. I would never do a comp. test by starting and running the engine. For an injected engine, I would disable the inertia switch. Some people test with wot and some with a closed thottle. Cold engine and hot engine.
Jivepepper-
Those numbers look pretty good for a cold engine. They are also well within a 10% variance.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • Gulftown980x
  • Jul 29, 2026
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
