Compression test today / oil on plug
fox-gt
204
TN
Went to have some work done to the exhaust today and I had them do a compression test also. My #6 cylinder has oil on the threads and I am having to replace the spark plug once a week.
(Previous Post with pic)
http://forums.stangnet.com/showthread.php?t=626877
They said all my cylinders had at least 145 to 158 of pressure (which they said was good). They recommended my next step be letting them check under the valve cover to reseach the oil leak. One guy recommended replacing the heads completely with some aluminum aftermarket heads. One guy said I could have the stock heads rebuilt. The engine is mostly stock, 140,000 miles.
What do you think?
I have to save for a few months no matter which way I go.
Oil control issues in a single cylinder does suggest a bad valve guide.
Most machine shops will want to replace the valve guides, atleast clean up the valves, and replace the valve seats. This can get pricey.
The high cost of "fixing" the stock head is probably why it was recommended to just buy new al. heads. There are aftermarket iron heads out there that can be had for cheap too.
