  • 1994 - 1995 Specific Tech
Computer Help
  • Thread starter Thread starter DFG 5OH
  • Start date Start date Oct 24, 2004
DFG 5OH
1,341
Louisville, KY
Oct 24, 2004
  • Oct 24, 2004
Any of you guys have any computer knowledge? I dont wanna post on a comp. forum, and it you guys know anything it will help
G
gradient
52
  • Oct 25, 2004
not posting the question just wastes time
DFG 5OH
1,341
Louisville, KY
Oct 25, 2004
  • Oct 25, 2004
tonight, i was at my girlfriends house tonight and was workin on her computer. I had to format her hard drive, because her computer was messed up bad. She has windows 98 Pro, and i put in the disc in the D:, and had the startup disc in the a:. When the command promt came up, after i selected start the computer with CD-ROM support, i typed "format c:" after it was done, i figured i could restart the computer, and the disc would automaticly start, and i could install the OS. But it sent me back to the command promt, and i dont know what command will start the windows 98 CD in the CD rom drive to install.
belzebub2u
164
Woodstock GA
Oct 25, 2004
  • Oct 25, 2004
hope this helps
when you get to command propt (a type D: (enter)
setup (enter)
should start ya
DFG 5OH
1,341
Louisville, KY
Oct 25, 2004
  • Oct 25, 2004
i tried that, but to luck, i'm got a few options, and i'll post back later when i get done, any more input will help
H
helix007
71
  • Oct 25, 2004
go to bootdisk.com and get a win 98 bootdisk , put it on a floppy then throw it in there before you boot up. Basically, your PC wont be able to even see the D drive (cd-rom) until you load the drivers for it.
That boot disk should get you going. post up if you need more help.
BlackVert
5,589
9
98
Bethesda, MD
Oct 25, 2004
  • Oct 25, 2004
you have to put the operating sytem back on it when you format it. otherwise it is just a data disk that you can't boot off of, like a floppy.
it has been a while since i had a 98 machine, but if i remember correctly, the command is "format c: /s"
now you have to boot off a bootable floppy. i think you can use "sys c:" to transfer the system files after it is formatted. or you can reformat it with the above command.
good luck.
1slow95
1,797
ohio
Oct 25, 2004
  • Oct 25, 2004
Type in D: to switch to the cd rom, then type in "cd win98", then you can type setup to start the win98 install.
DFG 5OH
1,341
Louisville, KY
Oct 25, 2004
  • Oct 25, 2004
I've got the bootable floppy that i made with the windows 98 disc. I have not yet ran the sys c: command, and i think thats what i messed up on, because i've been reading, and i need to do this. I'm gonna try and, and if theres no luck, i was reading my Windows 98 book and it says that you can install windows 3.1 which i have, and upgrade to windows 98 easily.
Thanks again for all the replys, i really hope this works.
DFG 5OH
1,341
Louisville, KY
Oct 25, 2004
#10
  • Oct 25, 2004
  • #10
Well i tried tonight, but had no luck, i kept getting this message when trying to use a cd:
CDR101 not ready reading drive D, Abort, Retry, Fail
I'm not sure, maybe the CD drive is bad? i'm gonna change IDE cables, and the drive out with another one to see if its bad or not.
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
1994 - 1995 Specific Tech May 21, 2026
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
C
96-984.6 COBRA MOTOR
  • COWBOY2.3
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
COWBOY2.3
C
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
