Confused
  • Thread starter Thread starter BrandonG08
  • Start date Start date Mar 28, 2015
BrandonG08
38
Florida
Mar 28, 2015
  • Mar 28, 2015
I got an 89lx 5.0 and I went out and tried to start it the other week and nothing well I jumped the seliond and fired up ran for a couple minutes and died it was running real rough found a lot of water in the intake so I did the gaskets got the car to fired on a 351 firing order ran but ruff switch back to the mustang order ran but still pop and cracks also has no top end at all. It also keeps dumping fuel like crazy have no top end p
TROY7
37
any where I roam
Mar 29, 2015
  • Mar 29, 2015
Check distrib module near base of dist ,Ihave a 89 bronco had a similar issue pulled one at a junk yard put it in and problem solved
BrandonG08
38
Florida
Mar 29, 2015
  • Mar 29, 2015
R u saying the tfi module or the pip
TROY7
37
any where I roam
Mar 29, 2015
  • Mar 29, 2015
I think that's the technical name for that part....when mine went bad at first it caused a weak spark, which caused crappy mileage ,then one day while I was out it just quit
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 30, 2015
  • Mar 30, 2015
Do these steps in the sequence as shown here and you will save time, money and energy. If one step doesn't fix it, then go to the next step. Chasing rabbits all over the place isn't a productive way to work...
The 351 & HO mustang firing order are the same.
This doesn’t prove that the block is a HO block. Some trucks evidently use a HO firing order with a low lift cam (this will result in less than the desired HP output). However, it will definitely prove that a block can’t be HO because the firing order is wrong.
Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Don't throw parts at a problem -Diagnose!!!
If the car has set unused for an exteneded period of time, it may have water in the gas, or bad gas. Get all the water out of the fuel system - siphon or pump out all the gas and put fresh gas in the tank.
Pumping out the old gas:
If the old pump still works, you can use it to pump the tank out.
1.) Separate the pressure line (the one with the Schrader valve on it) using the fuel line tools.
Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling.
OR
Use a piece of garden hose to run from the pressure line to your bucket or gas can. Make sure it is as leak proof as you can make it. Fire and explosion are not part of the repair process...
2.) Jumper the fuel pump test point to ground.
Turn the ignition switch to the Run position. the fuel pump will pump the tank almost dry unless the battery runs down first.
If you decide to use a siphon, a piece of 1/2" garden hose stuck down the filler neck will siphon all but a gallon or so of the gas.
Some 5 gallon paint pails lined with garbage bags are good to hold the gas. The garbage bags provide a clean liner for the pails and keep the loose trash out of the gas so you can examine for trash and water. if you find water or trash, replace the fuel pump filter.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 30, 2015
  • Mar 30, 2015
The 5.0HO and 351W have the same firing order. If you switched it to a non HO 302 firing order, it's no wonder that it won't run.
BrandonG08
38
Florida
Mar 30, 2015
  • Mar 30, 2015
I had it on a 90's model 351 and I sounded like it had a cam but just wasn't right fixed that and I was a tooth off on the distubitor but got the fixed cleaned my mass air flow sensor and I am getting code 98 and 51 put a new ect in the heater tube but still over fuels bad
BrandonG08
38
Florida
Mar 30, 2015
  • Mar 30, 2015
Btw the engine was running when I dumped codes
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 30, 2015
  • Mar 30, 2015
No such thing as being a tooth off on these distributors. That is why the distributor moves sideways to adjust the timing.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
