  • Mustang Sound & Shine All
Connecting to fuse
  • Thread starter Thread starter zincyellow03
  • Start date Start date May 23, 2005
zincyellow03
My dead ho likes Chicago
May 23, 2005
  • May 23, 2005
I'm trying to connect my sub to my fuse box but I don't think ford has an accessory fuse. Me and a friend of mine searched for it but we couldn't find it. He said that I'm going to need a switch to turn it on and off (which is fine to me but it's extra work). Which fuse would I be able to connect to?
Thanks,
Max
1hotz
I have no life, and I drive a Chevy... just shoot
176
sioux falls s.d.
May 23, 2005
  • May 23, 2005
do not connect to your fuse box, run a line for the amp from the battery with a inline fuse. and for the switching the (labeled rem on the amp) should be hooked to a switched 12 volt power (if you are using factory deck) or the remote (sometimes labeled remote lead, system lead, amp lead, or REM) lead on the deck (if you are using a aftermarket deck).
an easy to get a proper fuse size is to take your RMS power rating and devide it by 13.4, then round up.
example
500 (RMS power)
devided by
13.4 (average idle voltage)
equals
37.3
rounding up gives you a 40 amp fuse at least.
zincyellow03
May 24, 2005
  • May 24, 2005
ok, thanks
nhra427
169
Oregon
May 25, 2005
  • May 25, 2005
example
500 (RMS power)
devided by
equals
37.3
Not to cause problems but you should size your fuse to the wire you run from the battery to the amp. The amp should be fused somewhere on it for the amp. Hate to see someone run a 12 gauge wire and fuse it 50 amps or so. 1hotz is right about how much the amp will need so run a wire that will be big enough to handle the power you will be using
zincyellow03
May 25, 2005
  • May 25, 2005
Never knew you could do that. I'll look into it. Thanks
1hotz
176
sioux falls s.d.
May 25, 2005
  • May 25, 2005
thanks for correcting me on the oversight. i completely forgot about wire size also.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
2005 4.0 V6 Anti Theft Issue
  • Brysen
  • Dec 8, 2024
2005 - 2014 S-197 Mustang -General/Talk- Dec 13, 2024
89ripper
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
