Considering this Rad... a few questions though
Gellpak
147
Raleigh, NC
http://store.summitracing.com/defau...earchinresults=false&N=0&target=egnsearch.asp
Found that by searching... problem is I drive an automatic, do I need something extra on my rad to accomodate that? I've seen mention to radiators being "compatible with automatics" and I need to make sure. Also, will I need to have any brackets fabricated to fit this?
Also, I found a direct bolt-in 3 row brass radiator in my local Advance Auto (http://www.partsamerica.com/ProductDetail.aspx?mfrcode=GNO&mfrpartnumber=433259&parttype=31&ptset=A)... is the above aluminum rad significantly better than would be this brass one?
As I remember, your stocker is 17" wide. The circle track rad will not just drop in. Yo ucan prolly find a way to bolt it up, but you will need to trim the rad suppot else the extra width of the rad will be blocked from air flow.
Brass 3-row is fine in a stock or mildly modified motor. If you have, or will have, a hiPo motor, then an aluminum rad will give you more cooling potential. Your local climate should also be factored in.
