control arms or subframes
  • Thread starter Thread starter jmd2914
  • Start date Start date Jun 17, 2005
J
jmd2914
937
Napa, California
Jun 17, 2005
  • Jun 17, 2005
im ordering an electric fan and i wanna order either one of the two along with it control arms or subframes im kind of on a limited budget so if anyone has any imput feel free to put it. i.e up sides to both
stangbear427
2,401
New England
Jun 17, 2005
  • Jun 17, 2005
Get the subframes and the control arms, and get the fan later.
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
Jun 17, 2005
  • Jun 17, 2005
Ditto that.
C
CobraGT87
Mr. Speed Density
1,876
USA
Jun 17, 2005
  • Jun 17, 2005
Ranchero5.0 said:
Ditto that.
J
jmd2914
937
Napa, California
Jun 17, 2005
  • Jun 17, 2005
why wait on the fan? cuz i think my fan clutch is about to go. what kind of subframes and control arms should i get? and just for later on what kind of fan should i get?
vikingpower
656
CWU Ellensburg, WA
Jun 17, 2005
  • Jun 17, 2005
I read somewhere that subframes should be the very first thing you should do to your mustang, and use full length, they are only a few bucks more than the shorter ones. Not like I am one too talk, because I have yet to put some subframes in mine too!
Curse
791
El Paso, TX
Jun 17, 2005
  • Jun 17, 2005
I don't have aftermarket control arms, so I can give you an opinion there. When I first got my car it flexed like crazy, it got worse when I took my front sway bar out. I bought some D&D motorsport weld on SFC w/seat brackets, once installed the flex was gone. The car felt stiff and wouldn't rattle like mad going over bumps. From my experience I would get the SFCs ASAP. Good Luck
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Jun 17, 2005
  • Jun 17, 2005
This reminds me, i need to have my SFC welded in....they've been sleeping under my bed for a good year
C
criticman
723
Rome, GA
Jun 18, 2005
  • Jun 18, 2005
Not to steal the thread...but I too have SFCs sitting in a closet...would an exhaust shop be able to weld them on for me? And how much should one pay for the welding job?
camarokiller5.0
48
Dallas
Jun 18, 2005
#10
  • Jun 18, 2005
  • #10
Yep! I paid $30 , i wouldnt pay more then $30-$50, they should be able to do it in 30-40min. Good luck!!
5LugFoxFanatic
LOVE AND PEACE!
1,058
Arctic Tundra Hell, Twin Cites, Minnesota, USA
Jun 18, 2005
#11
  • Jun 18, 2005
  • #11
No need for aftermarket control arms if you are just using a daily driver. I would suggest boxing the stock ones and then running poly bushings in the whole rear except where the upper arm connects to the differential. If you put full length subframes on your car, and your car is lowered, it is hard to get a lift under it, if that matters. I would do full length, and remove your carpet when you do it, or it'll burn through,
stangbear427
2,401
New England
Jun 18, 2005
#12
  • Jun 18, 2005
  • #12
By the time you're done boxing the stock ones you may as well have bought far superior aftermarket ones. Unless, of course, you are a welder and can do all the work yourself, or know someone who won't charge you for it.
After having had several stangs with stock control arms, and several different aftermarket ones, I would never choose an electric fan over them. IMO, they are a must have item. If you think your fan clutch is crapping out, it will be cheaper to just get a flex fan and spacer in the meantime- and eliminate the clutch entirely- than it would be to buy and install an electric fan. Just my $.02
C
criticman
723
Rome, GA
Jun 18, 2005
#13
  • Jun 18, 2005
  • #13
Or just go to the local parts store and pick up a new fan clutch for cheap!
stangbear427
2,401
New England
Jun 18, 2005
#14
  • Jun 18, 2005
  • #14
That's no fun though... don't you know the Fox-body code?
"When something brakes, upgrade!"
vikingpower
656
CWU Ellensburg, WA
Jun 18, 2005
#15
  • Jun 18, 2005
  • #15
Thats pretty funny
J
jmd2914
937
Napa, California
Jun 18, 2005
#16
  • Jun 18, 2005
  • #16
hes right though thats been my thought when building this car, my car was lowered when it came from saleen so is it gonna be hard to get a jack under it if i do subframes?
stangbear427
2,401
New England
Jun 18, 2005
#17
  • Jun 18, 2005
  • #17
I've found working at the shop that buying stock replacement parts in any form other than OEM is just Russian Roulette (using four bullets instead of one), and many far superior aftermarket "upgrades" cost less than the OEM parts do. So we can keep it stock, or save money and make it better
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:11 PM
2000xp8
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
